OKay, here's the story. I have a 93 R32 Skyline and i'm running out of ideas. I'm running on 4 cylinders right now and here is what i've checked.
-swapped injectors (all are believed to be good)
-swapped coil packs (all are believed to be good)
-changed plugs
-compression test is good all across
When I pull the coil pack plugs on 2 and 6, nothing happens.
When I pull the injector plugs on 2 and 6, nothing happens.
The car runs rough, however still runs, has loopy idle, and is sluggish off the line. The only thing I can think of is the harness, but i get get continuity, I get spark for the coil packs and I believe the injectors are firing.
I'm at a loss, can someone help or suggest anything?
Thanks
https://www.sau.com.au/forums/topic/317127-dead-cylinders-26-misfire/
To believe the injectors are firing is not good enough.
Run the checks or take it to someone who can. A noid light will help you check for injector pulse.
Have you actually checked spark on all 6 or just assumed they were firing?
Make sure the ECU plug is pulled in straight as this is usually the first thing people stuff up when playing around.
What was the last thing that you did to the car before the misfire appeared?
I changed the wheels, lol. It was actually a bump and slightly and right after was the misfiring began.
But really, I checked spark in all cylinders, checked codes on the ECU today, so I know thats not it (no codes BTW). One of the injecters had no pulse but I hard wired from the resistor and and everything is good.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
