hay guys, iv been doin research on the IBC and heaps of stuff, but not really helping with that im after. iv just installed a gizzmo IBC on my r33 gtst. which has front mount and 3" zorst.
i just cant seem to get what psi i want. im only after 10psi at the moment. i hav duty at 10ish i think and gain at 2.. i stoped it going over 15psi. what am i doin wrong.
can som1 explain how to set it properly. i have read the manual online and still stuck.
what settings should i use? if any1 could help that would be awsum
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/
set the gain to zero.
then increase the duty up slowly whilst accel in 3rd or 4th (4th better) usually the duty will be between 30 and 35 to achieve 13-14psi BUT everycar is slightly different as the gate pressures vary slightly.
once the boost is set increase the gain until it spikes then come back 5 points.
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5186532
set gain to 0. and duty at min 10. still goin over 10psi??
check that your solenoid is hooked up correctley. what is the boost run when the solenoid is removed from the circuit? ie boost source straight to the actuator?
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5189186
with the standard boost controll it was stock. lyk 4psi untill 4500revs than a little bit more
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5190681
boost to port 3 actuator to port 2 on the solenoid? nothing else tee'd into those lines? they must only go to the solenoid then directley to the actuator. Post a pic of the install.
One other thing is the vacuum source to the main unit kinked or squashed at the firewall grommet?
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5190774
i will post a pic up 2moro afternoon after work, im pritty sure i have the rite ones. i bascially just copyed the stock ones. but the post to intercooling piping is going where the stock one was, wich is off the plumbed back pipe off stiock bov, next to block above zorst manifold and to left. the line going in2 the unit goes through the passenger gromit, no pinching that i could see. ill post a pic 2moro.
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5190795
nar turns out plumb back pipe was the problem, so im guesing it would only allow air to get in wen it blew off. its now connected to a T somewhere else and workes perfect. thanx for ppls help
thats what i noticed in the pics, the boost source for the solenoid was in the wrong spot (hookes to std boost controller dump port in the plumb back line)
https://www.sau.com.au/forums/topic/317170-gizzmo-ibc/#findComment-5197104
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
