daniel was at home ironing his blose as usual
ha ha tee hee :(
as the vehicle is up for sale at the moment it is pretty much living it's remaining days under my ownership in the garage. It's being cleaned, fussed over and polished, but not really driven.
I've been down the GOR once with the 34, actually stayed at skene's creek (the place up the hills in the trees) - some amazing roads that's for sure... too bad when i went down some of the worst storms in many year passed through the area and Vic (april '08 i think, lots of power outages all across melb and down that way as well) - candles and fireplace were needed at the accomm. Car loved it down there though, ate it up.
Grant, great to hear it was a simple fix. Told you you took it to the right place :rofl:
  • Replies 92
ha ha tee hee :)
Grant, great to hear it was a simple fix. Told you you took it to the right place ;)
Yeah the reason I'm going to Trent cos he is very easy to talk to and always helpful with my questions unlike many places.
so there were no metal shavings in the block? that's awesome!
p.s. merowyn say's hi :D
Yeah about one bit of metal shavings on top of piston 3, Peter and I suspected it is spark plug but I'll drain the oil just to be safe. I still have oil pressure which indicates the motor is tight.
Hi Merowyn :D
Will,
Yeah but I had to fork out $680 (2 x towings) for this damn thing.
When I'm going to put the HKS 2510s I've got sitting in my R, I'll replace the rest of clamps just to be safe.
Cheers
Grant
i got sick of the cooler pipe blowing off so i went nuts with hose clamps like this. http://www.norma.net.au/norma-gbs.html NEVER lost a pipe since! :blink:
Ron,
Ta for the link, how much did these set you back if you don't mind sharing?
Cheers
Grant
Ron,
Cheers
Grant
dont use them.... worst clamps ever (read attached link... i bin about 30 a week). T-bolt clamps are a terrible trend started by autosalon dudes who like shiny stuff. Norma make some killer clamps which actually work see this link.
end rant :blink: lol
http://www.skylinesaustralia.com/forums/In...lamps&st=40
lol well Trent is a mechanic and i am not so id take his word on that 1. ;)
as soon as i sort out this stupid idiot insurance claim ive got going at the moment and get some extra cash i might come stir you up Trent. i gots a few things i need fixed! lol :D
Trent,
That is quite a rant, these clamps are too chunky for my liking anyway. And you bin about 30 of these a week?!
Will have you to replace the standard ones with the one you put in my R other day when I'm ready to shit my pants with more killerwasps.
Cheers
Grant
Wouldn't bigger turbo happen to be one of these 'few things' you need fixed?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
