daniel was at home ironing his blose as usual
ha ha tee hee :(
as the vehicle is up for sale at the moment it is pretty much living it's remaining days under my ownership in the garage. It's being cleaned, fussed over and polished, but not really driven.
I've been down the GOR once with the 34, actually stayed at skene's creek (the place up the hills in the trees) - some amazing roads that's for sure... too bad when i went down some of the worst storms in many year passed through the area and Vic (april '08 i think, lots of power outages all across melb and down that way as well) - candles and fireplace were needed at the accomm. Car loved it down there though, ate it up.
Grant, great to hear it was a simple fix. Told you you took it to the right place :rofl:
  • Replies 92
ha ha tee hee :)
Grant, great to hear it was a simple fix. Told you you took it to the right place ;)
Yeah the reason I'm going to Trent cos he is very easy to talk to and always helpful with my questions unlike many places.
so there were no metal shavings in the block? that's awesome!
p.s. merowyn say's hi :D
Yeah about one bit of metal shavings on top of piston 3, Peter and I suspected it is spark plug but I'll drain the oil just to be safe. I still have oil pressure which indicates the motor is tight.
Hi Merowyn :D
Will,
Yeah but I had to fork out $680 (2 x towings) for this damn thing.
When I'm going to put the HKS 2510s I've got sitting in my R, I'll replace the rest of clamps just to be safe.
Cheers
Grant
i got sick of the cooler pipe blowing off so i went nuts with hose clamps like this. http://www.norma.net.au/norma-gbs.html NEVER lost a pipe since! :blink:
Ron,
Ta for the link, how much did these set you back if you don't mind sharing?
Cheers
Grant
Ron,
Cheers
Grant
dont use them.... worst clamps ever (read attached link... i bin about 30 a week). T-bolt clamps are a terrible trend started by autosalon dudes who like shiny stuff. Norma make some killer clamps which actually work see this link.
end rant :blink: lol
http://www.skylinesaustralia.com/forums/In...lamps&st=40
lol well Trent is a mechanic and i am not so id take his word on that 1. ;)
as soon as i sort out this stupid idiot insurance claim ive got going at the moment and get some extra cash i might come stir you up Trent. i gots a few things i need fixed! lol :D
Trent,
That is quite a rant, these clamps are too chunky for my liking anyway. And you bin about 30 of these a week?!
Will have you to replace the standard ones with the one you put in my R other day when I'm ready to shit my pants with more killerwasps.
Cheers
Grant
Wouldn't bigger turbo happen to be one of these 'few things' you need fixed?
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
