Hi all,
Just finished fixing my L/H headlight (Projector had come loose inside unit) now since I have put it back together all I am getting when I turn my headlights on is every indicator light turning on and no headlights. My parking lights work fine its only when it is flicked over to low beams. So far I have checked all the globes, wiring and connectors, as well as the indicator stalk (have had many issues with the stalk before). Oh and when I turn the high beams on the indicator relay goes spastic as well as the indicators themselves. Can any one shed some light on the issue
Cheers
https://www.sau.com.au/forums/topic/317235-headlight-issue/
Crossed wires somewhere dude. Something fishy has been done somewhere thats for sure!
Hi all,
Cheers
https://www.sau.com.au/forums/topic/317235-headlight-issue/#findComment-5191247
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
