3lt R33 Gtst
Up for sale is my 95 R33 GTST, i have only just got it going after a year off being off the road it has a fresh RB30 bottom with forged arias pistons and percision forged H beam rods i have the build sheet for the engine, fully balanced bottom end, 1/2" head studs cometic head gasket. Its running a Garret gt3540 turbo with custom steam pipe manifold and PSR external wastegate, plazmaman plenum and 80mm billet throttle body, 540cc nippon denso injectors, ViPEC plug n play engine management, it has a larger fuel pump but unsure of the size, front mount cooler 600x350x3 powder coated cooler piping, extreme cusion button clutch. It has 20's on it 2 are unroadworthy and comes with 16's with roadworthy tyres. Body is average conditon have freshly painted side skirts which arent yet fitted. Jvc head unit with 6" splits in the front 12" sub. The new engine has done about 500km on the dyno its running a rich tune at the moment it has 270kwaw will make 300+. It has done about 1500km on the road. Regretfull sale i need a quick sale as i am buying a house and unfortanatly it has to go. If i have forgot anything or u have any questions contact Dan on 0439619136. any resonable offer will be considered vehicle sold as is. $14000ono Sorry about pics i had trouble getting them on here i will try get them up if not i can send some pics via email or MMS.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
