Hey guys,
So my brother jumped in his '94 camry this morning and went to start the engine, only to cause a massive bang and steam to come from the engine bay. The battery had exploded, blowing one of its sides mostly off.
Any ideas what could have caused this?
Cheers
https://www.sau.com.au/forums/topic/317272-battery-exploded/
he just had the alternator replaced, does that give any help? sorry to ask, but im just interested in knowing, if the bonnet was open and/or someone was nearby they could have got a good splash of acid. also, want to avoid this ever happening to my car lol
Just last month, the same thing happened...
http://ozfoz.com/forum/viewtopic.php?f=16&...xploded#p274957
I'd hate to imagine what could happen if your cranium was under the bonnet and you asked someone to start the donk > :)
OR...
would it be any less tragic for it to happen to my battery next to the petrol tank. > RIP
Happens more often than you'd think, mostly on machinery that has a rough ride. Trucks, earthmovers, tractors etc.
The connections from the posts to each cell deteriorates and eventually you get a weak link just waiting for you to hit the starter.
Big amps and a spark in an atmosphere with hydrogen makes short work of the battery case.
Lucky it was just a single battery.
Bigger machines have 24V with 4X6V batteries side by side, so when 1-blows it usually takes all the others with it.
Lots of acid..........................................
here you go , the battery can crack down the side from being held by the bracket allowing gas to escape through the top seal , explosion caused by the gas mixed with air and the inrush current through the battery internally when starting . see it happen from now and then
Need to be a member to see that link terry..
Apologies - just noticed the deja vu so soon after an '06 Forester battery went Kabooom
I wonder "grigor" if this is what can happen with boats too? = a combo of evaporated fuel + deteriorated connections to the cells (especially in salty air)?
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
