Hey guys,
So my brother jumped in his '94 camry this morning and went to start the engine, only to cause a massive bang and steam to come from the engine bay. The battery had exploded, blowing one of its sides mostly off.
Any ideas what could have caused this?
Cheers
https://www.sau.com.au/forums/topic/317272-battery-exploded/
he just had the alternator replaced, does that give any help? sorry to ask, but im just interested in knowing, if the bonnet was open and/or someone was nearby they could have got a good splash of acid. also, want to avoid this ever happening to my car lol
Just last month, the same thing happened...
http://ozfoz.com/forum/viewtopic.php?f=16&...xploded#p274957
I'd hate to imagine what could happen if your cranium was under the bonnet and you asked someone to start the donk > :)
OR...
would it be any less tragic for it to happen to my battery next to the petrol tank. > RIP
Happens more often than you'd think, mostly on machinery that has a rough ride. Trucks, earthmovers, tractors etc.
The connections from the posts to each cell deteriorates and eventually you get a weak link just waiting for you to hit the starter.
Big amps and a spark in an atmosphere with hydrogen makes short work of the battery case.
Lucky it was just a single battery.
Bigger machines have 24V with 4X6V batteries side by side, so when 1-blows it usually takes all the others with it.
Lots of acid..........................................
here you go , the battery can crack down the side from being held by the bracket allowing gas to escape through the top seal , explosion caused by the gas mixed with air and the inrush current through the battery internally when starting . see it happen from now and then
Need to be a member to see that link terry..
Apologies - just noticed the deja vu so soon after an '06 Forester battery went Kabooom
I wonder "grigor" if this is what can happen with boats too? = a combo of evaporated fuel + deteriorated connections to the cells (especially in salty air)?
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
