Item Summary: Silver R34 GTR for sale silver, very clean, priced for quick sale
Condition: Very Good
Reason for Selling: Buying a house
Asking Price: 45000 ono
Km's: ~72,000
Delivery Methods: PickUp
Contact Info:
Mobile - 0402 926 628
Email: [email protected]
Or PM
Extra Information:
This is a 1999 model Nissan Skyline R34 GTR. It is a regretful sale but I am buying a house. There is nothing wrong inside or out with this car, Mechanically A1. Who ever buys this car will not be disappointed.
Extra's on this vehicle:
* Complete Apexi Exhaust system
* 2 x K&N pod filters
* 18" 'Genuine' NISMO rims (265x35x18 rubber on all four corners)
* Full car alarm (insurance compliant, 3 point immobiliser etc)
* New A.R.E. intercooler built for the car
* Oil catch can
* 4 x new tyres
This car is pretty much standard. Still have all original parts (air intake, oil breathers) for the car. These will go with the car when sold. Since I have had this car, I have fussed over it being perfect. There has been no shortcuts taken. I would say this car is in showroom condition, inside and out. Engine is running Motul 300V engine oil.
I am a mature aged owner and a car enthusiast. This car only really gets driven on weekends, and not even every weekend. Always kept garaged. Whoever buys this car will not be disappointed. I am selling the car as I am purchasing a house.
This car also comes with 10mths rego
Price is: 45,000 ono
Edited by BookyVL
https://www.sau.com.au/forums/topic/317296-r34-gtr-for-sale-great-price/
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
