hey everyone im in the market for a rear bar
been looking for ages cant seem to find the one:(
ive been looking at the trial rear bar the carbon fibre version with
the rear diffuser (looks tuff :P )
what you guys recon i should get? bar or pods? and what one?
cheers :(
https://www.sau.com.au/forums/topic/317301-cant-decide-on-a-rear-bar-for-my-33/
Diffusers only fit standard rear bars.
So you would either have to heavily modify one or make one from scratch.
Nismo rear bar or if you want to add a rear diffuser, get the Top Secret rear add ons and then you can use the diffuser.
cheers for the advice guys!
ill have a look at the 400r rear bar
yes it is a gtst with gtr front end i found a guy with cheap parts
cheaper then the s1 r33 parts i needed! lol
this is what i was looking into :ermm:
i was going to fibreglass those shit holes on the bottom lol
Lol uwuish shutup it's beter then having nothing on there , it looks so shit my gtsr badges are
still coming :D I don't no y gtr owners full get cut haha
yer trial bar looks schmik I'm going to have a look to
tomorrow
I can't find a decent pick of the 400r rear does anyone hav pics
cheers
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
