scotty nm35 Posted April 19, 2010 Share Posted April 19, 2010 Im about to order a set of braided lines in from the UK, just wondering if the 350z has the same length lines front and rear. Anyone changed them over? HEL have colored lines with stainless fittings for $120 delivered from UK, looks like the best deal by far. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/ Share on other sites More sharing options...
zei20l Posted April 19, 2010 Share Posted April 19, 2010 AFAIK they are different. the fronts are longer due to the front driveshafts Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5187991 Share on other sites More sharing options...
scotty nm35 Posted April 19, 2010 Author Share Posted April 19, 2010 Is there any that do fit? I can get custom ones made but they don't have stainless fittings, only zinc, and they are 3 times the price. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5188022 Share on other sites More sharing options...
zei20l Posted April 19, 2010 Share Posted April 19, 2010 try www.maltech.com.au for custom lines. they are fantastic quality (used them on 2 S15s) and will make up pretty much whatever you want Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5188063 Share on other sites More sharing options...
Jetwreck Posted April 19, 2010 Share Posted April 19, 2010 Told you I could help you spend money!!! Payback is sweeeeettttt Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5189045 Share on other sites More sharing options...
chuckie Posted April 19, 2010 Share Posted April 19, 2010 G`day Guy`s , i have contacted Phil about GroupBuy & Stagea Line`s As S2 are 835 mm long with the 3 block`s, so he`s going to see what they may cost , Not sure if MN35 are same so may be you will POST up few Photo`s & give us some Size`s , cheer`s Chuckie. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5189077 Share on other sites More sharing options...
zei20l Posted April 20, 2010 Share Posted April 20, 2010 i bet you M35 brake lines are different, being that they are different cars and all Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5189818 Share on other sites More sharing options...
richzx Posted April 20, 2010 Share Posted April 20, 2010 How much shorter are the 350z lines? If its just a couple of cm would that really make any difference once the line is pressurised? Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5189871 Share on other sites More sharing options...
zei20l Posted April 20, 2010 Share Posted April 20, 2010 i think its because we have a front driveshaft, and the line bolts onto a different spot, and needs a slightly different length to make it to the caliper Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5189962 Share on other sites More sharing options...
rb26stagea Posted April 20, 2010 Share Posted April 20, 2010 assuming they are the same; I may have made an error and bought non-brembo braided lines for my V35.... If this is the case, I'll pm you: they cost me less than the advertised price you stated... Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5190660 Share on other sites More sharing options...
chuckie Posted April 21, 2010 Share Posted April 21, 2010 Guy`s any hope of PHOTO`S of your LINE`S ,as i need to get some size`s of then to see if there same as S2 or S1 ,hope to see some soon cheer`s Chuckie. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5192229 Share on other sites More sharing options...
chuckie Posted April 21, 2010 Share Posted April 21, 2010 ok i have the Photo`s of S2 stock line`s they are about 830mm long with block conector`s & hard line.i know the Block`s are a fixing block so whether we really need them ?,iam not sure they are really needed as long as we have something to tie them with to keep out of harm`s way,ok so may be SOMEONE with MN35 will give me some feed back so we can LOOK AT the GROUP BUY ON BRAKE LINE`S , Cheer`s Chuckie Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5192474 Share on other sites More sharing options...
iamhe77 Posted April 21, 2010 Share Posted April 21, 2010 Well, going by the illustrations in FAST, NM35's share front brake lines with one other car... the V35 "S.4WD" from 2001-2004. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5192546 Share on other sites More sharing options...
scotty nm35 Posted April 21, 2010 Author Share Posted April 21, 2010 They are definitely different Chuckie. I will get Maltech to make a set up for me, then hopefully anyone else will be able to order a set through them. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5192569 Share on other sites More sharing options...
chuckie Posted April 21, 2010 Share Posted April 21, 2010 They are definitely different Chuckie. I will get Maltech to make a set up for me, then hopefully anyone else will be able to order a set through them. Hi Scott i sent PM to Phil about them with some Photo`s he will look when the kit`s come, & will let us know what to go is , can you take some Photo`s & post them up with lenght`s so we have some idea on what were looking for , Cheer`s Chuckie. Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5192579 Share on other sites More sharing options...
bigkevracer Posted August 6, 2011 Share Posted August 6, 2011 Did you guys end up getting braided lines? I thought I read something about Scotty and Ironpaw getting G35 Stoptech lines and making them fit, but a bit of searching hasn't found anything. Maybe I was imagining it? Is it even worth worrying about for a road car? I'm about to get some stuff from the states and they have reasonably cheap G35 lines, wasn't sure if I should do it when I did rotors and pads. Maltech et al seem to think the life of a rubber line is 6 years, so mine will be well and truly past that... Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5952742 Share on other sites More sharing options...
scotty nm35 Posted August 6, 2011 Author Share Posted August 6, 2011 I had Maltech quote a set for me, it came to $700. I decided to go the G35 lines. I havent fitted them yet, should be this week when the Brembos go on. Ironpaw's lines went on fine but they dont just bolt up like the stock ones... Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5952886 Share on other sites More sharing options...
bigkevracer Posted August 6, 2011 Share Posted August 6, 2011 Whats the difference in fitting? Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5952911 Share on other sites More sharing options...
JayM35 Posted August 7, 2011 Share Posted August 7, 2011 forgetting the 4wd, would 350Z lines fit a rwd M35? Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5953830 Share on other sites More sharing options...
Daleo Posted August 7, 2011 Share Posted August 7, 2011 (edited) forgetting the 4wd, would 350Z lines fit a rwd M35? I'm sure you'd be ok; the 2WD front end is the same as a V35/Z33 front end. I've sold a number of V35/Z33 front bars to go on 2WD M35's Perfect fit ; no issues. Edited August 7, 2011 by Daleo Link to comment https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/#findComment-5953881 Share on other sites More sharing options...
