Im about to order a set of braided lines in from the UK, just wondering if the 350z has the same length lines front and rear. Anyone changed them over?
HEL have colored lines with stainless fittings for $120 delivered from UK, looks like the best deal by far.
https://www.sau.com.au/forums/topic/317310-m35-braided-brake-lines/
G`day Guy`s ,
i have contacted Phil about GroupBuy & Stagea Line`s
As S2 are 835 mm long with the 3 block`s, so he`s going to see what they may cost ,
Not sure if MN35 are same so may be you will POST up few Photo`s & give us some Size`s ,
cheer`s Chuckie.
assuming they are the same; I may have made an error and bought non-brembo braided lines for my V35.... If this is the case, I'll pm you: they cost me less than the advertised price you stated...
ok i have the Photo`s of S2 stock line`s they are about 830mm long with block conector`s & hard line.i know the Block`s are a fixing block so whether we really need them ?,iam not sure they are really needed as long as we have something to tie them with to keep out of harm`s way,ok so may be SOMEONE with MN35 will give me some feed back so we can LOOK AT the GROUP BUY ON BRAKE LINE`S ,
Cheer`s Chuckie
post-36964-1271832905_thumb.jpgpost-36964-1271833111_thumb.jpgpost-36964-1271833485_thumb.jpg post-36964-1271834829_thumb.jpg
They are definitely different Chuckie.
I will get Maltech to make a set up for me, then hopefully anyone else will be able to order a set through them.
Hi Scott i sent PM to Phil about them with some Photo`s he will look when the kit`s come,
& will let us know what to go is ,
can you take some Photo`s & post them up with lenght`s so we have some idea on what were looking for ,
Cheer`s Chuckie.
  • 1 year later...
Did you guys end up getting braided lines?
I thought I read something about Scotty and Ironpaw getting G35 Stoptech lines and making them fit, but a bit of searching hasn't found anything. Maybe I was imagining it?
Is it even worth worrying about for a road car? I'm about to get some stuff from the states and they have reasonably cheap G35 lines, wasn't sure if I should do it when I did rotors and pads. Maltech et al seem to think the life of a rubber line is 6 years, so mine will be well and truly past that...
I had Maltech quote a set for me, it came to $700. I decided to go the G35 lines. I havent fitted them yet, should be this week when the Brembos go on.
Ironpaw's lines went on fine but they dont just bolt up like the stock ones...
forgetting the 4wd, would 350Z lines fit a rwd M35?
I'm sure you'd be ok; the 2WD front end is the same as a V35/Z33 front end.
I've sold a number of V35/Z33 front bars to go on 2WD M35's Perfect fit ; no issues.
Edited by Daleo
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
