hey its a bit of a noobe question i know but any help would be great. My boost controler is set at 1.20kg and 30% duty on the high and 0.95kg and 30% duty on low boost my question is jus how much boost am i running on both settings ive downloaded the instruction manual but im lost on the whole equation on how you come up with the end pressure anybody had any experence with the avc-r.......
thanks in advance
https://www.sau.com.au/forums/topic/317335-apexi-avc-r-boost-settings/
I don't think those duty cycles will be right either. Mine is running .80kgcm2 @ 36% duty cycle.
From memory the manual states a higher duty cycle for higher boost. But I had a lot of trouble setting mine up, took about 35 minutes on the freeway. And then my tuner done it in about 5 pulls on the dyno. They're great when they work properly :)
yer i didnt think it was installed corectly the gauge on the controler is only reading 0.75bar on the low and 0.95 on the high looks like a trip to the dyno is on the cards....
thanks for all your help................
