fuel tank is about 65L, best to use premium fuel, but not a must. as for fuel economy, as with every car it really depends on how you drive. if you like flooring it everywhere then you will get noticably worse economy than someone who drives like a granny
yeah, hence not being fussed about replacing the O2 sensor. I just have that feeling that I should be getting a bit better efficiency from a 2.5 litre 6... But maybe im just getting more and more upset at the increasing cost ($) to do said 100km- aka fuel prices
:P
i think that if your o2 sensor was bad you'd be getting worse than 12L/100kms of "brisk city driving"
it really comes down to how you are driving. if you are flooring it a fair bit then you will get poor fuel economy, even in something like a skyline with a relatively small engine. they aren't exactly tuned to be economical either. they are tuned to be a bit sportier, so that means that even driving like a granny you would use more fuel than some other 2.5L engines out there.
i was getting much worse economy than you in my r33 gts-t. i was up around 17L/100kms. on a long trip on the higway it was down around 10 or 11/100kms. new o2 sensor made no difference because it was down to my driving style. the o2 sensor has no effect on how rich the car runs when you floor it. the ecu ignores it once you get into higher load cells on the map. this can be as low as about 40% throttle depending on rpm, etc. the o2 sensor is only used in light throttle applications, so light acceleration and cruising along at a steady speed.
before you go out and buy a new o2 sensor you would be best off just testing your current one with a multimeter to see if it is working properly.
il whack in about $50 so half a tank aprox, will last me about 250 k's, but its all driving style. i try and change around 3k rpm but its not always the case haha, and i do alot of stop start driving aswell which dosent help.
after getting the new tuned ecu in and boost controller retuned I found that i was in the 20L/100km bracket for 'very spirited' driving. New O2 sensor goes in this week...
Laid waste to an EVO so it was all worth it :3some:
also girlfriend screaming real loud and grabbing the jesus bar and the roof under full acceleration. LMFAO
  • 1 month later...
Have put in the new NGK O2 sensor, sealed up the filler cap leak so now have an airtight seal on the petrol tank,
also put on a turbo-back exhaust and done a further tune and now down to 12.5L per 100km for brisk city driving.
Stoked.
Ill flush with injector cleaner and do a final tune and hopefully under 12L...
Laid waste to an EVO so it was all worth it :)
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
