Need more Zed Pics!
Sure thing...
Any more pics of the Impul R32 GT-R thanks
Sorry; haven't got any other pics of it :blink:
nice pics! got some talent!
Thanks a lot :(
awesome pics
Cheers! :)
nice shoots man very nice keep up the good work
Thanks a lot :blink:
A week back i covered a dance performance and it was one of the toughest gigs i have ever done. The change of lighting every second, the fast dance movements, not understanding what the dance meant and the stage being about chest height.. But i had fun which is the main thing and didnt do too bad. What i found was that when i shot with a 70-200L lens, it produced a little less noise at 1600 compared to a 50mm f1.4. Oh and did i mention the people in the front row with digi cams taking shots with flash every 5 seconds.
I hate that; taking pics with people with little point and shoot digital camera's having bursts of flash going off just as i'm about to hit the shutter, happens all the time!
Some really amazing photos in this thread! Very talented.
Thanks a lot, really appreciate it :)
good job man keep it up
Thanks, will do :)
______________
Got a few more pics from a recent meet-up
  • 2 months later...
do you use filters or polariser when taking these to bring the contrast or colours, or is it all post production work?
Nice pics, I am very much an amature but I enjoy learning and experimenting with my 40D...
Nice shots mate, looks like your getting HDR down pat!
It's all HDR (High Dynamic Range).
Basically you can take one RAW photo and create a single HDR by adjusting it +/- 1 or 2 stops and then stack them.
OR
Take bracketed shots (3-9 shots at different exposures all a stop apart) and then combine them in photoshop or Photomatix or any HDR compatible program.
Plenty of info out on the web about it :down:
OR
Thanks, I will try that...
Those two blue 34GTR's really look nice with the HDR effect. I think it suits the photo.
By the way, you need to clean your sensor! If it's not your sensor, you need to clean your lenses and/or filters! So much dust spots in the last two photos!
I'm only using a UV filter on it, the contrast/colour work is all post production.
nice shots!, i think the 32GTR ones look best
These are so nice. Well done!
Thanks!
Great! It's very nice. :huh:
Haha yeah, it's cleaned now :D I looked at the photo once I uploaded it to my computer and I was like :O
__________________________________________________
Might as well update this with a few of my most recent shots...
  • 1 month later...
Here is some HDR photo for my 350z too
I took 5x shoots using same aperture but difference shutter speed and using "Photomatix Pro" in the mac to marge to HDR.
What program do you guys use to Marge to HDR?
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
    • Tapin,    So got mine up and realize a few things. First was my slave line doesn’t reach the other side, so I have to get a longer hose made. I want to ask did you have to extend your wires for the CD009 sensors? One on the driver side(right side of car looking at the car from the rear) and one on the passenger side( the left side of car from rear). And do you know what those two sensors are respectively? I know it’s not Speedo since we talked on this already. And I may have to separate the trans again to swap out throw out bearing. We will see. Did you run your RB slave cylinder? I know you cracked your original but replaced it with a nismo. But wasn’t sure if you bought the one designed for the CD009 or not. Thanks
