I was at Eastern Creek yesterday and had an issue with the car that ruined the day. I have no idea what this is but here's what happened:
Car would only rev to about 3.5 to 4k at 11psi; it is tuned for 16psi in this range. From there the car would flutter and not want to rev any more. The problem is, this only occurs under full load acceleration; with light acceleration it's happy to rev to red line.
I checked all the hoses and nothing was loose and couldn't hear any leaks.
It's an R33gts-t and does anyone have an idea what this may be because I've got nothing??
https://www.sau.com.au/forums/topic/317390-car-not-holding-boost/
I know you said you've checked all the hoses but that would still be my guess. On a track you are full load/full boost way longer than on the street, and things you might overlook can be loose.
so...check again....all clamps on the inlet....bov returns.....vacuum hoses....you need to look for splits as well as loose clamps too, tiny splits can open under boost but not be noticeable normally.
unless it sounds like a wrx of course!!
Thanks for your replies
Nah it didn't sound like a wrx. Car sounded normal and until it reached that flutter accelerated like normal.
I'll have to re-check all the hoses on it.
It's got after market coilpacks on it. I know it's an issue but how bad are these for going through coilpacks (as in after market ones)?
what spark plug gap are you running?
my car was boost surging from 16psi to 13psi on sunday on the way to eastern creek, i worked out the boost controller was playing up, after turning the boost controller off and running stock boost the boost was fine,
is your boost surging or the engine missfiring/ spitting?
what fuel pump your running?
OK I've had another look through the car the other day. I made a mistake above and the car does hold 16psi when it does this.
Checked the exhaust to see if it was a blocked cat but when the exhaust was off the car did the same thing but only when it was at half throttle.
Checked and cleaned spark plugs - all okay.
Unfortunately I didn't check the coil packs when the spark plugs were off. I will check these though. There's Splitfires on there but I don't know how long they've been on the car for.
Any ideas on what else that may be wrong with the car?
Hey.
When did you last change your fuel filter? It may be partially blocked.
Gap your plugs to 0.8mm.
Also What voltage are you running with your pump? If it hasn't been done already, you need to wire it directly to your battery with a 30amp relay in place for correct operating voltage.
If you are using the stock AFM you may also need to change it.
RB25DET AFM's are temperamental things especially when compared to Z32 or even R32 and don’t like to run too much boost through them especially on cold days/nights.
What ecu are you running?
If its stock the problem may also be a factory safe guard known as ‘rich and retard’.
If you running Splitfire’s they should be fine but if you’re concerned have them tested.
All in all it’s just a process of elimination but to me it sounds like air/fuel ratios are out which is known to occur around this rev range on RB25DET which tells me its running rich.
I hope this may help you in some way.
Cheers.
Hey.
RB25DET AFM's are temperamental things especially when compared to Z32 or even R32 and don't like to run too much boost through them especially on cold days/nights.
If its stock the problem may also be a factory safe guard known as 'rich and retard'.
If you running Splitfire's they should be fine but if you're concerned have them tested.
All in all it's just a process of elimination but to me it sounds like air/fuel ratios are out which is known to occur around this rev range on RB25DET which tells me its running rich.
Cheers.
Thanks heaps for that info. I hadn't checked the pump to see for blackages yet; regarding the voltage, I'm not sure what it runs but I'd presume it would be wired in for the appropriate voltage. Will double check though.
I probably should have put these up earlier but these are the engine mods the car has done to it:
Apexi Power FC
GCG turbo
Deatchwerks Injectors
Hybrid front mount intercooler
Z32 air flow meter
HKS boost controller
Apexi pod
Custom metal intake pipe
Splitfire coilpacks
Ganador 3” exhaust
Catco metal cat 5” body
JJR aluminium radiator
Nismo fuel pump
I don't know how long they have been on the car for. It's putting out about 260kW at the wheels
Edited by Gunnar_11
Sweet man, nice set-up.
Get a volt meter and check your pump for sure. It should be running at about 13-13.5 volts at idle if it’s been wired correctly. I forgot to mention that it might also pay to get a can of CRC MAF/AFM cleaner. This shit works wonders.
Other than that, I would change fuel filter and plugs (coppers, 0.8mm) for security and take it to a dyno to check air/fuel ratios.
still got the stock rubber in take? when they heat up they go soft an fold on them selfs stoping air flow
  • 2 months later...
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
