Counter Strike
SECURITY
 Share
i found my install cd's after being boxed up for 3yrs.. anyone still play this? i just got steam, not sure what else i need.
i kind of suck at it but wouldnt mind playing people who are shit at it too lol. im sick of getting owned by everyone online!!
  • Replies 59
CZ or Source.. there is a thread on here somewhere.. some still play it.. i play Source.. i'm really shit at it.. wanna battle.. lol
i play breakfloor_2k5 mainly.. i prefer it as it's quick rounds and not waiting around for the last couple to find each other while they are both camping.. either that or gg servers.. you get better real quick.. i was out for ages and when i got back in i got back up qucik enough.. just join -sniper servers that way you face them up closer
yeah it WAS good but then no one came on, and it was like Ash, me and Cozi who pwnd everyone else constantly. IMO TF2 is better for non hardcore FPS gamers, more fun than rage factor most of the time too!
lol yer... there was 2-3 others who were regulars.
I used to book the servers all for us etc...
And then only 6 people turned out... so it kinda died in the ass
my groups server is back to breakfloor.. anyone wanna play.. just add to your favorites and i might be on.. usually takes a while for the server to get more players but just incase
202.157.179.71:27052 <---- server address
added, but ive only got the normal counter strike, this one is counter strike source.. whats the difference?
found out that the server host accidently loaded our server back up (we stopped hosting cause we slowed playing and server is usually just small groups) so that server is free lol
when you say 'normal' counter strike, do you mean the original and Condtion Zero?.. they are heaps different in display.. i went back and played CZ and i found it hilarious compared to source and couldnt ever remember playing it in such a basic form lol
Get CSS and you will love it
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
