Counter Strike
SECURITY
 Share
i found my install cd's after being boxed up for 3yrs.. anyone still play this? i just got steam, not sure what else i need.
i kind of suck at it but wouldnt mind playing people who are shit at it too lol. im sick of getting owned by everyone online!!
  • Replies 59
CZ or Source.. there is a thread on here somewhere.. some still play it.. i play Source.. i'm really shit at it.. wanna battle.. lol
i play breakfloor_2k5 mainly.. i prefer it as it's quick rounds and not waiting around for the last couple to find each other while they are both camping.. either that or gg servers.. you get better real quick.. i was out for ages and when i got back in i got back up qucik enough.. just join -sniper servers that way you face them up closer
yeah it WAS good but then no one came on, and it was like Ash, me and Cozi who pwnd everyone else constantly. IMO TF2 is better for non hardcore FPS gamers, more fun than rage factor most of the time too!
lol yer... there was 2-3 others who were regulars.
I used to book the servers all for us etc...
And then only 6 people turned out... so it kinda died in the ass
my groups server is back to breakfloor.. anyone wanna play.. just add to your favorites and i might be on.. usually takes a while for the server to get more players but just incase
202.157.179.71:27052 <---- server address
added, but ive only got the normal counter strike, this one is counter strike source.. whats the difference?
found out that the server host accidently loaded our server back up (we stopped hosting cause we slowed playing and server is usually just small groups) so that server is free lol
when you say 'normal' counter strike, do you mean the original and Condtion Zero?.. they are heaps different in display.. i went back and played CZ and i found it hilarious compared to source and couldnt ever remember playing it in such a basic form lol
Get CSS and you will love it
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
