hi guys, found this from ebay, not sure it will fit my S2 AUTO stagea or not, i know Z32 N62 AFM will fit , but untill i saw this one R71, not sure is from Z32 or not, can someone comfirm for me please. I plan to mody my S2 stagea now, will plan to get bigger turbo and AFM.
https://www.sau.com.au/forums/topic/317456-afm/
That's a Subaru STI AFM. Probably won't work...
You'd be wanting either the stock 'Pink' label or a Z32 'green' label.
Note: With the Z32 you MUST have it tuned. It will not run otherwise.
all the Z32's i've seen including mine have an orange label. green label afm's can be found on the S1 RB25's and RB20's.
samkoek, unless you have an SAFC or Nistune or some other kind of aftermarket ecu control, a Z32 will be useless as the stock ecu wont run with it. stock afm should be good till about 200kw-220kw, so just keep that in mind as you might not need a Z32 AFM yet and can spend your coin on something else. also be-careful when buying Z32's on ebay, there are a lot of fake ones floating around that will not work properly. best advice for if your chasing a Z32 for future upgrades would be to either purchase it of one of the site sponsors on this forum, they often have deals going for SAU members. or see if there is a decent second hand one for sale on these forums.
https://www.sau.com.au/forums/topic/317456-afm/#findComment-5190387
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
