G'day
Friend of mine has an R33 GTST, recently he's been having issues starting it. Hot or cold, it does the same thing.
Turn key, tries to start and doesn't. Turn key again, hold accelerator on and it starts. Idles fine and it's all go after then.
We have:
Changed spark plugs
Changed the air filter
Cleaned the MAF sensor
Cleaned the throttle body
Changed oil + water
Replaced any hoses with small cracks (just in case)
Now I've heard alot of cleaning the AAC valve, so I will give that a try next. I also plan to change the fuel filter but I'm not too sure that will change things.
The other problem which may add to this is the alternator belt makes a loud squealing sound when the engine is cold, after it heats up it's fine. I haven't attempted to tighten this, someone else tightened it by simplying turning the nut on the front of the alternator but I wasn't sure if that was the way to do it or not.
Other than that, I'm at a loss and I can't think what the problem could be. He's not too mechanically minded so that's why I'm posting it all up for him.
Edited by hylian
I was going to suggest the AAC valve..
might be buggered all together but.. normally dirty ones will make it hunt..
But then if it idles all right it might not be.. ??? worth cleaning anyway..
Are you sure an injector(s) is not leaking. I too have this but my car must sit for about 12 hours before anything like the shudder only because my leak is so small at the moment. If it happens all the time it must be a bad leak!
The ACC probily wont have a thing too do with it because if it was falty it would continue too do it rather than stop after you accelerate. The only other thing i can think of is the cold start regualtor (under the stock throtle body) that may need a clean if the vavle is sticking. But my 2 cents are with the injectors
Are you sure an injector(s) is not leaking. The only other thing i can think of is the cold start regualtor (under the stock throtle body) that may need a clean if the vavle is sticking. But my 2 cents are with the injectors
How can we test if the injectors are stuffed? Or is that something that a workshop would need to look at.
I'll have a look at the cold start regulator, but it still does it when the car is warm so maybe not that. Worth a look though.
What do you mean by making it hunt?
I'm talking about idle hunting.. will rev up and down continuously on idle..
I don't think thats ur problem... if it still does it when warm (can you turn the car off and start it or do u need throttle??), I don't think it would be an injector..
yeah you have too get a pressure test done on the injectors (anyone who cleans them professionaly should also pressure test them aswell).
He will need $2900 if he wants too do it at home :)http://cgi.ebay.com.au/Ultrasonic-Fuel-Inj...=item3ef625efed
There are cheepo ways of doing it but dont risk blowing yourself up by fiddling with the fuel rail and ignition (a lot of americans have DIY for that :))
Im Almost positive its injectors because it does it when its warm. When you put the ignition on it pressureises a fuel system by priming the pump and the discription fit because i think one of the injectors is leaking heavily when he pressurises the fuel system
Could be an air temp sensor problem.
Is your mate running a pod? If he is - air temp sensor may have been disconnected.
Another problem could be a faulty tPS (Throttle Position Sensor)
He still has the MAF behind the pod filter, where is the air temp sensor located?
I'm not sure if this will have anything to do with it, but when we changed the plugs a few days ago, there was a bit of liquid around the edges of where the plugs would sit, looked like watery oil? Possibly a stuffed head?
Fiddling with the injectors and the fuel rail sounds out of my league so if it ends up pointing to that we'll take it to the experts.
Car doesn't idle hunt, it did when he blew an intercooler pipe though. We've fixed that problem.
As far as I know, turning the car off and then starting it again we still require use of the accelerator. I will also look at the throttle position sensor when I next get a look at the car.
Thanks for the help so far.
It's located in a GTR.
You'll have a bit of trouble finding one in a 33 GTSt.
I tried the suggestion you gave me (turning key to on and letting it sit for 5 secs) - didn't change anything car still does same thing.
I will have a look at the AAC and TPS this weekend.
Same thing happened to me the other day, I thought there was something wrong with my car coz it only started when I used the accelerator. Turns out it was only the battery going flat. Could it be something simple like that? Sorry noob stupid answer I know :)
  • 4 weeks later...
Same thing happened to me the other day, I thought there was something wrong with my car coz it only started when I used the accelerator. Turns out it was only the battery going flat. Could it be something simple like that? Sorry noob stupid answer I know :ermm:
I replaced the battery and it fixed the problem for a few days then it went back to normal. My guess is the alternator is about to die;
sorry about the late replies.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
    • I much prefer colder weather to hot weather, and especially prefer cold to hot and humid, Goulburn does gets pretty warm in the hotter months, but, I've found the humidity there is not as painful as even Sydney, the humidity up north is to oppressing for this old rooster  In saying this, it does get rather "nippy" in Goulburn for early morning, late in the evening walks, but nothing that a layer or two, some thermal gloves, and a beanie doesn't fix to make it an enjoyable experience, which is much more bearable to me than the oppression of heat and humidity,  especially at night when your trying to sleep If I recall correctly, a "wise man" once said that the "Southern Tablelands" was gods country, and I will not argue that point with him for the fear of a "permaban" LOL In car part related news: My intake is currently in Botany getting processed for the last leg of its shipping journey to my door
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
