1991 SILEIGHTY
For Pics: http://www.pandablue.com/nissansilvia/foru...4917&PN=1&TPN=1
Engine Modifications
· RB20DET 5 Speed Manual
· 0.90 BAR Boost
· Pod Filter with Cold Air Partition
· HKS Super Dragger Cat-Back Exhaust (85mm)
· 3” Hi-Flow Cat
· R33 GTR Fuel Pump
· ARE Hot Chilli Type 28 Front Mount Intercooler – Tube & Fin (610 x 300 x 75 mm core) with Hot Chilli End Tanks
· 2 ½” Inlet & 2 ¼” Outlet Mild Steel Piping with Blue Silicone Hose and T-Bolt Clamps
· Intercooler Water Spray – 2 Nozzles & Rocket Switch
· Custom ARE Triple Filtered OAS
· Garage Titan Customised RB20DET BOV
Suspension & Drive Train Modifications
· CUSCO 4.363 : 1, 2 Way Mechanical LSD
· URAS Urethane Drift Pineapples set to “All Round” & URAS Urethane Gearbox Mount
· UAS Master Brake Cylinder Brace
· Custom Front and Rear Strut Braces
· Bronzed 3 Puck Sprung clutch with 2200lbs (1000kg) Pressure Plate & High Tensile Bolts
· Machined Stepped Flywheel, New Thrust Bearing & New Pivot
· Reconditioned Clutch Master & Slave Cylinders
· HKS HiperMax D Coilovers (Camber, Height and Damper Adjustable) with Camber Tops and Pillow Ball Uppers
Interior Modifications
· HKS Type 1 Turbo Timer
· Blitz Dual SBC – Blue & Silver Version
· Twin A-Pillar Gauge Cups
· 60mm Apexi White Faced Boost Gauge – EL Series (2.0 BAR)
· 52mm Autometer Black Faced Air/Fuel Ratio Gauge
· Relocated Battery – Boot with Maxiblade Fuse Holder & 80A Maxiblade Fuse
· CUSCO Drift Hand Brake Button – Silver
· LEVOC Racing Pedals – Silver
· Blue Neon lights in foot well
· Polished Aluminum Ball gear knob with 6 blue LED’s
Exterior Modifications
· S13 Silvia Front End Panels
· S13 3 Style Projector head lights (with fog lights) – 2 Circle, 1 square
Wheels & Brake Modifications
· R32 GTS-t 5 Stud Brakes (front & rear – rotors & calipers)
· S14 Hubs – ABS
· R33/S14 Rims with Goodyear F1 225/50/16 rubber
Alarm & Sound System Modifications
· Viper Stage 5M Alarm – Microwave Sensors, 3 Point Immobiliser with Black Wiring
· Stock Nissan CD Player
The usual, regularly serviced (new diff, g/box oil, cleaned air filter, AFM, re-gapped plugs, new fuel/oil filters, etc). Done a genuine ~70000km's (engine approx 72000 and car 73000). Rego till 10/2004, Very good condition. All fully engineered with certificate for suspension, exhaust, engine, etc. Can provide reciepts.
$14,000.
Firm.
Email: [email protected]
Mob: 0407 179 830
https://www.sau.com.au/forums/topic/31747-fs-1991-sileighty/
Noooooooooooo don't sell it mate. That car rocks!!!!!!! Come on dude, what we gonna go cruising in when i come down to see you guys eventually on my holidays coming up.
You've done heaps and all the niggly things as well? The next car you buy your gonna have to do that as well remember!! Come on mate!!!
https://www.sau.com.au/forums/topic/31747-fs-1991-sileighty/#findComment-645576
    • I have an Elite 2500, honestly most of this has been a lot of smaller tasks chasing little details and a whole lot of life getting in the way of bigger projects. I don't mind too much looking at a spectrograph vs having audio knock ears.
    • Nah nah nah nah. Don't do it. It's not all about the full throttle power delivery. The main "street fun" and drivability gains from smaller rear (in this case) is how you will have boost available from a low rpm when yo just roll onto the throttle. Think jinking in and out of traffic, coming out of roundabouts, etc etc, where you just want to roll onto the throttle a little and have the spooly noise from ~2000rpm and a swell of torque. More of what you've already achieved by going to 2.5. And then, towards the tail end of 2025 you can pull the turbo 4 out and put in a V8 like we originally suggested. :P
    • Cheers for the info mate, I'm old too, 60 years old next May, so a more linear delivery of the 0.86 would be better as baking tyres and snapping heads isn't on the cards for me or the car I assume a more linear power delivery would be better for engine and drivetrain reliability as well, IRT the torque load at lower RPM???, as well as lower EGT's???, if my understanding of that is correct, have I got that right??? I've only got a really basic understanding of turbo sizing and all there characteristics  Cheers for the useful information
    • What kind of power delivery are you after? If it's nice and linear, the 0.86 would be better. If you're after bake tyres and head snaps on boost the 0.64 would be fun. I'm boring and old, so linear power is preferred. Lately I've been watching videos on Z06 Corvettes and super charged Mustangs....
    • I’d go the smaller rear just because you’re staying on 98, if e85 I’d go the bigger one
