OFMG... 19s?! i should have waited! :worship:
But on the bright side, received the wheels today! i am super happy, fast service, wheels came as promised!
best service i had for a while!
thanks guys!
  • Replies 199
Hey Ken,
Do the wheels come from the factory with red sticker on already or do you have a choice of not having the stickers attached? I think the red sticker is 'loud'. I am interested in a set - 18X10.5 +15; that is the right offset for R34 GTR?
Matt
u beautyyyyy :)
how much??? (for the various 19" sizes)
19x9.5 $3950 Pre-order $3750
19x10.5 $4050 Pre-order $3850
19x11 $4100 Pre-order $3900
Production for the 19's will finish at the end of October and we're hoping it'll be here in Early December.
Cheers
Ken
Hey Ken,
Matt
Thats what i ordered for my 34 gtr. The sticker comes in the box for you to fit if you desire.
Hey Ken,
Matt
Hi Matt,
Stickers come in the box and it's your choice to stick them on or not.
Yes, 18x10.5+15 is a perfect offset for the R34 :)
What size offset with these two sizes can I fit on an R34 GTR? +15 maybe?
What is a package price with the before mentioned KU36?
Thanks
19x10.5+12 or +22
19x11+23 (might be abit much, might rub inner guards)
can do any of the combination with 285/35/19 KU36 for $4900
Anyone got pics of these actually on a white car? I am keen but tossing up between these and black te37's. Not sure if these will be dark enough. If they look dark enough put me down for a set :( 18x9.5 +12
Edited by topher_
Anyone got pics of these actually on a white car? I am keen but tossing up between these and black te37's. Not sure if these will be dark enough. If they look dark enough put me down for a set :) 18x9.5 +12
Here is a picture on a white car :P
Sorry they don't come in +12, only the following 18x9.5+22, 18x10+20 or 18x10.5+15
We're waiting for the first production to finish at the end of October before we can get any pictures :)
Man I need to be in on this. I need to get ten posts so I can PM you. I'm after:
17 x 9.5 +12
18 x 10.5J +15
What's the price now?
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
    • Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay.  Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
    • Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
