OFMG... 19s?! i should have waited! :worship:
But on the bright side, received the wheels today! i am super happy, fast service, wheels came as promised!
best service i had for a while!
thanks guys!
  • Replies 199
Hey Ken,
Do the wheels come from the factory with red sticker on already or do you have a choice of not having the stickers attached? I think the red sticker is 'loud'. I am interested in a set - 18X10.5 +15; that is the right offset for R34 GTR?
Matt
u beautyyyyy :)
how much??? (for the various 19" sizes)
19x9.5 $3950 Pre-order $3750
19x10.5 $4050 Pre-order $3850
19x11 $4100 Pre-order $3900
Production for the 19's will finish at the end of October and we're hoping it'll be here in Early December.
Cheers
Ken
Hey Ken,
Matt
Thats what i ordered for my 34 gtr. The sticker comes in the box for you to fit if you desire.
Hey Ken,
Matt
Hi Matt,
Stickers come in the box and it's your choice to stick them on or not.
Yes, 18x10.5+15 is a perfect offset for the R34 :)
What size offset with these two sizes can I fit on an R34 GTR? +15 maybe?
What is a package price with the before mentioned KU36?
Thanks
19x10.5+12 or +22
19x11+23 (might be abit much, might rub inner guards)
can do any of the combination with 285/35/19 KU36 for $4900
Anyone got pics of these actually on a white car? I am keen but tossing up between these and black te37's. Not sure if these will be dark enough. If they look dark enough put me down for a set :( 18x9.5 +12
Edited by topher_
Anyone got pics of these actually on a white car? I am keen but tossing up between these and black te37's. Not sure if these will be dark enough. If they look dark enough put me down for a set :) 18x9.5 +12
Here is a picture on a white car :P
Sorry they don't come in +12, only the following 18x9.5+22, 18x10+20 or 18x10.5+15
We're waiting for the first production to finish at the end of October before we can get any pictures :)
Man I need to be in on this. I need to get ten posts so I can PM you. I'm after:
17 x 9.5 +12
18 x 10.5J +15
What's the price now?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
