  • Replies 199
  OTR said:
Hi Scott,
Got your deposit thanks.
No, Rays have released more offsets and sizes for other cars too
Cheers
Do you know what size rotors fit the 17 X 9,5 +12 ? These are my old 345 brake kit in 18 x 9.5 +12 LM GT-4's (there's a little bit of space here). The guy I sold them to squeezed them into some 17's (almost perfect fit actually).
The SL is supposed to have better clearance yeah? I still cannot see a 355mm kit fitting.
Cheers
Scott
Edited by K-Style
Cheers
Scott
Hi Scott,
SL should have the same clearance as the regular TE37, the mods to save weight was shaving on the other rim..
  N1GTR said:
What other sizes are out?
Supra sizes in 19's?
I'm not sure on the offsets of Supra's, below are the sizes;
17's
17x7.5+40
17x8.5+40
17x9+22
17x9.5+12+28+35
18's
18x8.5+35
18x9+45
18x9.5+22+35+40
18x10+20
18x10.5+15+22
18x11+18
19's
19x9.5+22
10x10.5+12+22
19x11+23
  • 3 weeks later...
Guys, we have left from our container arriving mid November the following TE37 SL including 19's!!! So wants to be the first in OZ to fit SL's on their Skyline??!!
4 x 17x9+22 $3200
4 x 18x10.5+15 $3500
4 x 18x11+18 $3600
4 x 19x9.5+22 $3700
4 x 19x10.5+22 $3800
  KING87 said:
How long until you get some 19x10.5 +12 in? In not in a great rush
They will be going on an R34 GTR will this be a good size without rubbing or poking out?
Cheers
Matt
Hi MAtt,
We have 4pcs arriving in this shipment, not 100% sure with the rubbing...may have to ask the R34 GTR guys on this forum for advice.
Cheers
Ken
Cheers
Matt
depending on how much castor and camber you're running. More castor you pull, the more chances you'll rub the plastics. I have about 1.5 deg camber and 6 deg castor and it rubs at near full lock.
You've got mail Ken!
Thanks Eugene, i have seen a few 34's with 19x10.5 and it does look tough. If it only rubs on full lock i can live with that.
Cheers
Matt
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
