  • Replies 199
hi this is anthony . just baught te37 SL 18x10.5
awesome customer service. top bloke. very funny haha
thanks for the help il post up a pic when there on
cheers
  • 4 weeks later...
Price for matte black TE37 18x10.5 +15 please kind sir
(and what is the estimate waiting time?)
also, price for TE37 sl same size delivered, do you have stock?
  • 4 weeks later...
Hi Tom,
We need to order them in and I'll take at least 4months from time of placing the order.
What we have arriving in Flat Black that may interest you;
TE37SL
1set 19x9.5+22
1 set 19x10.5+22
A few sets 18x9.5+22
LMGT4 Gloss Black (This is a special order and only a few limited sets)
A few sets 18x9.5+12
  On 29/10/2011 at 7:05 AM, OTR said:
Hi Tom,
TE37SL
1set 19x9.5+22
1 set 19x10.5+22
Thanks, can you please send me prices for the options you have listed.
  • 3 weeks later...
  • 4 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
