  • Replies 60
Posted Images
What are you using the car for, I only ask this as Im unhappy with my outcome, I would rather more response than to a turbo that comes on late and hard, my set up is more suited to drag but I wanted track. The spool time is crap, its like waiting-waiting-waiting-wheel spin.
Fair enough, what turbo& setup are you using? I'm mainly going to be using mine for street, with the odd track/drift/drag, basically looking for an all rounder ay.
Picked up the first lot of goodies today :wub:
Shiny new Arias forged pistons 9.5:1 compression
+ piston rings
And, most importantly, stickers....
First step on the way :( smoky burnouts here i come! lol
Having had a bit of a read through some more stuff i'm thinking i'm gonna definately get some forged conrods and go for a t04z. Would the engine as i'm plannin it atm handle that size turbo? what, if anything, would i need to change for that to work well? The head is definately gonna get a light porting and stronger valve springs, adj cam gears and aftermarket cams plus 850cc injectors adjustable fuel reg and so forth
Also, just thinking about using the TiAL 50mm BOV, would that be high flow enough? I like the sound of em lol but if it won't flow enough i'll go for a another option. What do you guys reckon?
Just make sure you get a twin scroll rear housing and keep it small and get a manifold to suit.
Sweet thanks mate
Can you give me some dimesions there in terms of "keep it small"? And what exactly is a twin scroll rear housing lol
small would be a .81ish A/R or a .84ish split pulse/twin scroll.
will be capable of making 400+rwkw or 540+hp
engine will handle the turbo, depends how much boost you run through it though.
the hydraulic lifters will be 'possibly' the weak link depending on psi and power
Edited by jangles
Cheers for the link/picture D_Stirls i now get the idea behind split pulse lol makes a lotta sense when ya figure it out!
Okay sweet so .84a/r t04z split pulse and a suitable manifold?
It already sounds awesome just typing it lol I cant wait haha
In terms of a split pulse manifold for rb30's who of the big companies make em? or is it more likely to be a custom made job?
sweet as, yeah i know a few good fabricators here i'll have a chat to, just wondering if any of the big companies make em off the shelf like lol
yeah i'll check rips out too, already planning on using a rips intake so getting an exhaust manifold at the same time makes sense even to me haha
these guys are pretty much the big companies when it comes to manifolds i think. apart from japanese gear.
a specifically suited manifold that is as good quality as the japanese stuff locally, offer lifetime warrenty too
did you consider rips building your whole motor? they do something really special with them haha
Edited by jangles
Yeah fair enough, i'll have a look around see what I can find out
Yeah, they're doing my r34 GTR VSpec II Nur...after i win lotto :D
lol yeah i did think about it but in the end it was just too expensive, plus to be honest i'm not looking for a car that insane lol
Edited by MNTLRB
ha yeah, price is always a key issue!
they build mild engines aswell though.
anyway, make sure you get a split pulse/twin srcoll manifold when getting a split pulse/twin scroll turbo.
i still dont think you need the TO4Z for your power goals, but it gives you head room for down the track!
Yeah, I know it's a bit over the top, but i'd rather do it once and do it right, and I just have a feeling that I'd probably end up changing to the t04z later on anyway so I figure I'm just saving myself time lol
And yeah I'm pretty sure I'm gonna get addicted to power hunting (I've already upped my power goal from when I started) so this is playing it safe lol
Haha and somehow I think it's only gonna get worse not better :(
so still need some idea on cams, anybody have ideas? Basically want mild gain but don't wanna have to modify the head extensively (doing full recon, mild port, reseat valves and aftermarket valve springs, adjustable cam gears)
anybody know what stock cam specs are for r32 25de head?
go with the biggest drop in cams you can get to suit, i wouldnt bother with the DE cams for what youre going to do.
http://www.kelfordcams.com/applications.aspx#Nissan
local to you, and are a great bit of gear
drop in wont even matter.
if the head is apart, u can get it clearanced to suit bigger.for not much more.
something around the 262 9.3 would be good. H182-B
Edited by jangles
Yeah, i was never planning on using the standard cams, just wanted to know their specs so I can get an idea of what sorta increase any aftermarket ones were.
For those ones (H182B) I would only have to get the head clearanced for them to work ok?
Also I cant really tell from the website, I assume the prices are US $?
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
