not sure about the prices, we pay 900 for them in AUS, not sure if its 900 in NZ or what the go is.
i think clearancing will be all,you will have to have a decent search on the hydraulic lifters in the head.
as i said before, depending, some people have issues at over 350rwkw,i think larger cams may impact also? dont quote me on it though.
in the below thread are all the RB cam specs
http://www.skylinesaustralia.com/forums/post-a282987-
Edited by jangles
  • Replies 60
Posted Images
Really depends where you want to make the power, my mate has 280' 10.5mm cams in his 25DET/30+T04Z, it's a bit laggy but fkn screams to 8000+, oh and sounds awesome :rofl:
I'm sticking with the DE cam for now as they made decent power in the last 30 setup, 365rwkw @ 21psi through a pair of 2540s (bad), stock throttlebody/plenum (RB20), and I'd prefer the lower down from the shorter duration, I'm not bolting a HUGE turbo (GT35R) on so small cams and keeping the rev limit sensible (7500ish depending on when it stops making power) is the name of the game for me.
I found the NZ version, it's $1200 nz...darn you auzzies and your exchange rate etc lol
will have a look into the lifters and see what I can find out, short on time atm haven't looked yet
Really depends where you want to make the power, my mate has 280' 10.5mm cams in his 25DET/30+T04Z, it's a bit laggy but fkn screams to 8000+, oh and sounds awesome :)
Haha I checked out a few videos of t04z + worked cam rb's and they do sound f***ing AMAZING! lol
More looking for midrange power than huge lag tho...do you think the Kelford 272's 9.35 or the 262 9.3 would still respond pretty well without lagging like a freight train?
Already have a 25 head to use haha
plus over here at least 26 heads are ridiculous prices, waaay more than doing a solid lifter conversion anyway lol (seen a bare rb26 head, ie no valves valve springs cams or cam gears going for near $1800 lol), and since i'm gonna have the 25 head apart to be reconditioned anyway...
which brands make a good solid lifter kit for rb's?
Just waiting on my solid lifter conversion kit to arrive.
Its a supertec setup that includes oversize inlet and exhaust valves, Solid lifters, dual valve springs, Retainers.
Dan at ERD organised it for me. Website below
http://www.erd.com.au/
I'd go for something around 260' in the biggest lift you can get (that will still fit your head).
Awesome, if you don't mind my askin how much did it sting you? PM me if you want.
Let me know how it works out for ya and how easy it is to install
Sounds good lol, now I don't know much bout cams so forgive me if this is a stupid question, if I go ahead with the solid lifter conversion will this affect how much lift there'll be in the head?
Just out of interest what did that cost you, if you don't mind me asking?
If you get cams to suit hydraulic lifters, and then do a solid lifter conversion, it will run like crap as the ramp rates (time for starting to open to full open, vice versa for closed) are different for hydraulic and solid lifters.
I think you only need solids if revving high as the hydraulics get to a point where they can no longer pump up in time before the next cycle.
around the 2500 mark mate. The conversion allows you a much more aggressive camshaft setup. (higher lift and more duration etc) Plus its way lighter than a hydro setup.
For this engine I'm planning to get an internal lift pump surge tank and two Bosch 044 pumps for the surge tank to engine, but I'm just after an idea for the actual surge tank and lift pump...what size surge tank would I need? What brands have you guys use and found good? And what kind of in tank lift pump would I need? As above engine setup will be RB30det with t04z aiming for 500rwhp
Hey
my setup is still in the process of being sourced / built
but as for surge tank, I'm using a 3L tank to 2 x 044 externals, walbro feed pump, 6 x 1000cc injectors
on a 26/30 with gt3076r 0.82 on E85... hoping for around 350rwkw...
Awesome, the 044's seem to be popular in most of the magazine articals I've seen just none of them list the size of the surge tank or lift pump lol. What sort of walbro lift pump are you looking at?
Wish e85 was commonly available over here...tho to be fair Im gonna be using mine on the street mostly so probably not practical lol...but still. lol
Okay, probably won't really be needed then, I'm only really planning to rev limit it at about 8000-8250 or so, so the hydraulic lifters will be able to handle that correct?
Not sure at 8000rpm.. I'm going to suck it and see how they go.
That's pretty overkill.. the 3L+T04Z I mentioned earlier is only running 1x 044 intank.
I asked my tuner a while ago whether I should run a surge tank and he said don't bother, they mounted an 044 nice and low in the tank for me and assured me that it would do the job as that's how they run all their drift cars. It went from surging if under half a tank when throwing 'nuts, to being able to whip 'nuts with no surging under 1/4 of a tank.
I'm only shooting for 500rwhp but I've got 1000cc injectors so IF we ever get E85 over here, I should only need to upgrade the pump setup.
pretty sure there is a thread for the fuel systems here somewhere,
a stock in tank pump is fine for the lift pump 2-4l seems to be the go for tanks,
make it a round one, as they are meant to swirl the fuel so no air gets in there.
Awesome thanks man! Is this another get one custom made sorta thing or are they fairly commonly available?
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
