Hi all.
I have some parts left over from a half-cut I bought. Pictures coming soon, but everything seems to be in good nick with the exception of surface rust on the rotors.
I have:
$300 R33 S2 GTST front calipers (including whatever pads are in them)
$200 R33 S2 GTST front discs (appear to be plenty of wear left)
$100 R33 S2 GTST castor rods/tension rods (rubbers look perfect!)
$50 R33 S2 GTST front swaybar
$50 R33 S2 GTST steering rack (one bent tie-rod, but rack came out of my car and was perfect before the tie-rod got hit)
$50 R33 S2 GTST front seatbelts (appears to have electric pre-tensioners)
$5ea R33 S2 GTST random interior trim pieces... both kick-panels, some windscreen vents etc.
Discounts for multiple purchases or pickup, will post anywhere at your expense. Open to offers.
Pickup is in Forestville, NSW.
Please reply here. =-]
-Steve
I guess editing posts has been turned off... here are the pics!
post-3573-1271822626_thumb.jpg post-3573-1271822641_thumb.jpg post-3573-1271822651_thumb.jpg post-3573-1271822660_thumb.jpg post-3573-1271822667_thumb.jpg post-3573-1271822677_thumb.jpg post-3573-1271822686_thumb.jpg post-3573-1271822701_thumb.jpg post-3573-1271822708_thumb.jpg post-3573-1271822729_thumb.jpg post-3573-1271822739_thumb.jpg post-3573-1271822749_thumb.jpg post-3573-1271822755_thumb.jpg post-3573-1271822762_thumb.jpg post-3573-1271822771_thumb.jpg post-3573-1271822777_thumb.jpg post-3573-1271822787_thumb.jpg post-3573-1271822794_thumb.jpg
Additions:
$5 R33 S2 GTST guard flasher
$100 R33 S2 GTST Foglight/Indicator internals. (wires have been cut, but glass/plastic looks to be perfect)
I don't know about cross-compatibility on any of these parts. I know the castor arms work on some silvias, and the calipers are sought-after for conversions....
They are 4-pot/piston, off an R33 Series 2 GTST. That is all I can confirm for sure. =-]
I had a feeling that the discs are a different size on R32's, and most conversions require the discs (294mm?) also.
  • 1 month later...
$300 R33 S2 GTST front calipers (including whatever pads are in them) Sold for $150.
$50 R33 S2 GTST Passenger seatbelt (pre-tensioner and seat buckle included)
$50 R33 S2 GTST Passenger side front quarter-panel in white, with indicator.
$50 R33 S2 GTST Braided oil and water lines for standard fittings. New and unused.
$25 R33 S2 GTST Radiator (auto). Reasonable condition, no leaks. (with cap)
$25 R33 S2 GTST Standard condenser. Reasonable condition, no leaks.
  • 4 months later...
$200 R33 S2 GTST front discs (appear to be plenty of wear left) Sold for $25
$100 R33 S2 GTST castor rods/tension rods (rubbers look perfect!) Sold for $25
$50 R33 S2 GTST front swaybar - currently on eBay for $20
$50 R33 S2 GTST Braided oil and water lines for standard fittings. New and unused. Sold for $60
$5ea R33 S2 GTST random interior trim pieces... both kick-panels, some windscreen vents etc. Binned some, kept others for myself.
Any offer considered!
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
