hey guys just wondering what is the better option. I know people say that there is minimal if any top end hp difference but ive also herd that cats also help with the exhaust flow through turbulence etc. Is this true? and if it were wouldnt a high flow cat be alot better for the car all round rather than a de-cat? Just wondering because ive just purchased a decat and wondering whether it was the right choice to go for a straight through 3" pipe (not counting the high flow muff before the cannon at the back)?
Cheers
https://www.sau.com.au/forums/topic/317509-decats-vs-catpipes/
Remember exhaust characteristics are different for an N/A and a turbo car. A dump pipe on a turbo car should theoretically be as big as possible, you want the best flow possible period. However, on an N/A car it is different, it is more complex, an exhaust restriction can help with down low power but reduce top end and vice versa.
Whereas a nice large dump pipe on a turbo will give better response and top end, its a win win. Up to a point obviously where any increase in flow doesnt make any difference.
In summary to your question, the decat pipe will be better performance wise on your turbo car.
Your cat must be very restrictive to cause such a change, most cars would barely notice a difference. When you remove it, the exhaust is flowing a lot better meaning more boost, meaning more air for the engine causing it to run lean.
Define running like shit? loss of power? If its extremely lean you will loose power.
Edited by Harey
so explain why my car runs like shit when i run open dump pipe but runs tops when i put a cat on?
soz 4 highjacking ur thread
probably coz it hasnt been tuned for that set up.
yeah exactly right,
when i had my cat taken off and a decat put on the tune was very lean and the car made 260rwkw on the same boost, which was down from 285rwkw with the cat, but with a little tweaking of the Nistune to correct the mixtures. the car was able to make 320rwkw with an extra pound of boost.
i went to a decat because my cat was restricting flow because the guts of it had come loose and was moving around in there.
if you got an aftermarket ECU get it retuned, if its stock. then maybe the extra flow is just too much for the ecu to handle?
A good high flow cat will be quite expensive, around the $500~+ range. Metalcat comes to mind but the postives outweigh the negatives, probably a small 10-15rwhp possibly to be made by running straight through but the legality of being found out with no cat and having your car slapped with a major defect and towed away makes up for that.
I was running a decat. I put my cat back in, and did feel the car seemed to run better or soother with it on. It was down a little in power....but the car felt better to drive.
Yup it could do that. Are you running the standard ecu?
All you are doing is improving your exhaust flow, which has to be a good thing, it just means sometimes the ecu is not ready for it and needs to be adjusted.
Had my car around three years now and when I first got it I used a holesaw with extension to core out my cat and the whole insides disintegrated and just simply fell out (alot easier than trying to bash it out. that’s if it’s in pretty good condition like mine was). I found that when I first did it my exhaust note changed ever so slightly (more aggressive but probably more due to gaskets constantly blowing out at the time) and boost response is slightly better and went to rev limiter fine on stock boost. HOWEVER since I have now fit FMIC and played with the boost a bit it definitely starts to lean out around 5000-5500 and above.
(I’m only running 8-8.5psi due to R&R as I have a massive CAI which was causing compressor surge and R&R. Its now partially blocked until I get Haltech and tune. And yes I have cleaned my AFM, gasket gooed, taped and cleaned my coils and re-gapped to .8.)
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
