hey all, disregard the post above. need to get rid of this whole car fast!!! still in parts tho but it all needs to go!!!! pm with the part you and and an offer and its most likly yours if i stil have it! Thanks all,
Daniel
do you have the igniter pack at all
ok heres a list of items i have... i have many more but yell if you want any of these... ill post pics if anyone wants PM me,
ENGINE BAY
-Bonnet Cable $ 50
-boot / fuel tank cable $ 60
-Carbon Canister $ 50
-Window Wiper Motor $ 60
-ABS Unit $ 260
-Brake Master Cylinder $ 70
-Windscreen washer btl $ 70
-Radiator o/flow btl $ 70
-air con condensor fan $ 40
-Radiator $ 100
-Brake booster $ 60
-Steering Columb $ 230
-steering rack $ 220
-speedo drive cable $ 180
EXTERIOR
-Rear Reo Bar $ 80
-Front Reo Bar $ 80
-Windscrn plastic panel $ 80
-mirrors $ 180
INTERIOR
-Carpet $ 100
-Front Seats $ 700
-Rear Seats $ 150
-Roof Trim $ 80
-Sun Visors $ 60
-Tail light Boot Trim $ 40
-Side Boot Trims $ 70
-Stero/Grboot Surround $ 60
-Centre Dash Piece $ 60
-A Pilar Trims $ 80
-Centre Console $ 80
-door Garnishes (floor) $ 100
-dash cluster surround $ 120
-windscreen vents $ 40
-Glovebox $ 30
-footrest $ 10
-Heater Unit $ 100
-centr dash vent $ 90
DRIVETRAIN
-front drive shaft $ 60
-front drive shafts $ 140
-Rear Diff $ 400
-Tailshaft $ 160
HANDLING
-Front Brakes W/Rotors $ 450
-fr lwr control arms $ 140
-fr hgh control arms $ 120
-fr castor rods $ 100
ELECTRONICS
-Engine Wiring Loom $ 250
-Dash Loom $ 100
-Engine Bay Loom $ 300
-Centre DIN Gauges $ 100
-Window Control Drivers $ 100
-Dash Cluster $ 150
-Exhaust temp sensor $ 50
LIGHTING
-Headlights $ 300
-Front Indicators $ 200
-Tail Lights $ 100
-Side Indicators $ 50
-interior lights $ 50
-number plate lights $ 50
OTHERS
-Fuel Tank $ 200
-attesa resevoir $ 60
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
