Hey guys. I was looking to buy my first Skyline, did my homework, looked around and ended up pretty happy with this R34 GTT. Picked up the bank cheque this morning, spent 1.5k on some fresh rubber and some stockies as he wanted to keep the rims, sorted out all the insurance, even had the transfer of ownership forms filled out and ready to be signed.
Did an inspection and compression test as a last thing this afternoon. Everything was looking good, no accident damage, no rust. Just needed new tyres, new brake pads..stuff like that. And then... compression test results:
160
150
105
155
100
110
:ermm:
It was totally unexpected, as the car runs smoothly, doesn't blow smoke or cough and sputter. Was really only doing it as a last peace of mind kind of thing. :l
The question now is, is it worthwhile getting a second opinion? It just seems kind of weird that not one.. not two.. but 3 of the 6 cylinders are leaking so badly, while the others are going strong at 150-160. I'm thinking it could be a dodgy test, but the mechanic said he double checked and got the same numbers, so I'm not too sure..
I'm really quite dissapointed :l If everything checked out, it would be in my garage right now!! :blush:
Has anyone here been in a similar situation or have any advice? Not too sure where to go from here :S
Thanks guys
Lyndon
I think its more likely to be incorrect compression test results unless it is running like shit or blows heaps of smoke on boost.
was it warm when you tested it
was the battery fully charged
was the cas unplugged
was the throttle fully open while cranking
was it a screw in or push in type of tester?
Surely the mechanic who compression tested it also did a leakdown test afterwards to tell you WHY the compression is down right?
If not, then get a second opinion. Sounds dodgey. I have replaced 2 comp test gauges in the last 4 years. They don't last forever
Thanks for the replies guys. The car was driven to the workshop, which is about a 30 min journey at freeway speeds, so I'm guessing it was done warm?
That's the thing though.. it drives very smoothly and doesn't blow a puff of smoke even when revved up to 6k rpm. Not sure what kind of test was done though, we just left it at the mechanic's and went to grab the transfer forms and transferred the car back onto regular plates. :S Was done at a workshop I found in the WA consolidated workshop thread, and was recommended to me by forum users D:
Had a chat with the seller, he looked genuinely surprised and said he definitely wants to pay for a second opinion, so I guess I'll wait for the results of that and take it from there. :S
Also, just curious- how does the leak down test actually work? I've heard it mentioned here and there, but not 100% sure what it actually means :S
Thanks guys :ermm:
Leak down test is similar to a compression test, but it measures pressure loss instead of pressure.
What they do is remove all the spark plugs, screw in a threaded coupling attached to a leakage gauge, and then feed about 80-90psi of compressed air into the cylinder. Any more than 30% leakage and you have a problem.
Leak down tests also make it alot easier to diagnose what the problem is, as Daniel pointed out. For example if you can hear the air coming out of the throttle body that would indicate a leaky intake valve. Or if a cylinder has poor compression but minimal leakage, that would usually indicate a valve-train problem, such as a collapsed lifter or worn cam lobe, etc.
i would probably say to get a second opinion if you're really keen on the car.
if you're not, or if the second test comes back bad, WALK AWAY!!
the last thing you want is to buy a Skyline that you know is going to need work, its not cheap.
and those that say it is cheap are lying.
Yeah.. if the second result is consistant with the first, I wouldn't hesitate to walk away. :blink: It's just that I'm not sure if the result is accurate. Would be a pity if I gave up on this one due to a dodgy test, as the mechanic said everything else was in top knick :l
Lol that's ironic James. The place I took it for the first test was Allstar Garage literally across the road from Hyperdrive xD
Will give them a ring tmr to see if they can book me in later this week.
Cheers
Allstar Garage are my favs... Sean is the best in my opinion. No harm getting a second test done though, better to be safe than sorry, especially if the owner is paying for it. How long in advance did you book in at Allstar lol, they book out like 2 weeks in advance... Suppose it wasn't being tuned though.
Definitely walk away from it if the tests come back dodgy, there are plenty of R34's out there, would suck if you bought one of the lemons.
I spoke to Sean on the phone and he managed to squeeze me in the very next day :D
It wasn't him who did the test though..was one of the younger mechanics.
Seller said he'll get it done again today.. will let you guys know how that goes.
I really am quite keen on this car! But if the results concur with the first... :D
Fingers crossed! :)
He was tied up with work, msged me saying he'll do it today with a kit he borrowed from work, as he's a mechanic. If that checks out, I'll get him to do another infront of me and then if a garage can verify it, I'm happy to take the car off him :) I'll let you guys know how it goes hopefully later tonight :S
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
