everytime i read all these bad things about N1's it makes me want to go straight down to the shed and unbolt mine. lol i must admit they were abitch at the track on sunday, no punch out of the turns unless over 5k, DVS32R was infront of me, his got n1's too, just got his car tuned, and you could see him pull away soon as the apex would end on the corners. Its got alot to do with Tune too. i see 8psi at 4.5k, i was running 16psi on the day seeing full boost by 5.8kish. Laggy as hell, would have to down change to second to keep it within powerband to punch out of corners. Plus loose even more time changing back up gears. ill prob go -5's when i do my build.
I can't imagine what another 100rwkw with the same (if not better) response would be like... but if I'm ever in NSW I'm coming round to find out! lol
I'm keen to try E85 next... figure as far as bang for buck at this point nothing can beat it
edit: yeah Paul the Mines 34GTR runs shorter diff ratios... I'm keen to try the GTS4 diffs, they are about 4.3 from memory... can't hurt the cruising speed that much, I hardly ever use 5th gear as with the big cams it runs more efficiently cruising at 3,500 - 4,000 rpm... you can hear its actually quieter at that rpm too which took some getting used to, looking down and seeing 4k on the tacho makes you want to shift up
Come to a DECA when im there :(
Its getting a new exhaust and more boost over the next few weeks
Do you, or anyone else know exactly what the Mines R34 has for driveline ratios?
Ive been in your car, before you owned it.
What a machine that thing is!
OP: As said, its up to you to find the amount of lag you're happy to put up with in the conditions you drive it in. Mine is between 3500/4000 and 8500rpm for HKS GTRS's although a 3L bottom end, that suits me, may not suit others. It would be a good idea to look through the dyno result threads in this section aswel, some decent info in there (aswel as a lot of crap results)
Dude, your car sounds like an Animal, boost from 3.5 - 4 K on RS's !
It all comes down to how much later will i make boost on my 2.7 then you do on your 30 ? if i could sort of get some idea of this i could either say "yep, GT-RS power" or -5's I have a feeling ide be pretty happy with both. the car is still street driven but im definately not one of these people who harps on about lag driving around town unless we are talking something monumental.
Thanks for the feedback guys.
Mitch.
Mitch.
Sorry, a tad higher than that, my bad;
I think it ran gts4 4.3:1 instead of the factory 3.6:1
plus epic close ratio gearbox
I thought the box was just a getrag though and the change was to the diffs and a carbon shaft?!
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
