Check Your Nuts
LSX-438
 Share
I tell you guys what IS the absolute best set of wheel nuts (sick aint it :happy:) I've ever seen or used, and that's Project MU's.
If money is no object (and this is beer money for you guys), I can't recommend anything more than these. They're steel, but of a hollow design so they are still light, and they have a captive washer on them so they don't bind.
We use these on Mark's R34 time attack car, and although the wheels have been on/off literally hundreds of times, they're good as new. Got them from Racer Industries on the Gold Coast.
From memory they're around $300 per set. I'll get these next, as they've proven themseves to me as good economy. (Drip a little oil between the washer and the nut itself prior to first use, just as you would tightening head studs, they torque up beautifully)
This is the type we use;
http://www.project-mu.com.au/en/products/o..._nut_racing.php
I have some of these & would recommend them above any alloy nuts.
It is pretty simple - you don't want them failing. You don't want to have to worry about them failing. YOu don;t want to have to continually replace them.
On that basis they are actually pretty cheap. Light too for that matter.
  • Replies 50
that's me. i just cant bring myself to pay $400 for wheel nuts. i understand the economy argument, but yes i'm a tyt arse!
If you check the obvious import sites you should be able to get them for less than $250.
Also Nismo make steel wheel nuts in various lengths. they don;t appear to have the little collar on them like the project mu ones, however.
can't seem to find any project mu stuff less than the $390 price, any suggestions?
Mine never failed but damaged the thread both on the nut and the stud, it got so bad that I had to replace my studs
same here. studs damaged due to the soft alloy thread coming apart and mashing the stud thread. pita. got to watch them closely and clean as you go all the time. a damaged stud can ruin your whole championship (i carry a bunch of spares now..!)
Yeah sorry I realised after i posted them, I thought I had seen them on there before for around the same price.
no worries. i think i found some decent ones (aussie made i think) through meridian motorsport, $150/set. apparently quite good i will report on them soon.
bit late....but anyway, I gave up on ally wheel nuts after stripping one. Don't need that sort of issue.
The ones I have run for years are steel from my mates at autobarn. take a nice thin 17mm socket and fit in most wheels. they have a flange so they don't slide into the deep sockets. look like this....thanks ascii art.
. __
\___/
I don't have an issue with using a rattle gun to spin the nut if you have long studs, but always stop early and finish them by hand with a torque wrench (unless the rattle gun has actually been calibrated to the right torque, 110nm for standard studs). I have seen studs stretch and break from not torquing right, it is just crazy not to take the time to do this stuff right on a track car. I use a makita electric impact wrench then finish off with a warren and brown torque wrench, does not take too long.
  • 3 weeks later...
I was just told something very interesting relating to annodised alloy parts. I was explaining the problem (stripping a lot of these wheel nuts) and his first question was "what colour are they"........ They have all been red, and he went on to say that annodising them RED has a weakening affect on them. Something to do with the process of annodising them RED whereas other colours didnt have the same problem! (to the same degree) he had some hardness numbers to back up what he was saying. So that's interesting, anyone ever heard this?
My red ones are also stuffed!!! I don't remember what brand they were but I bought them for $120 a set so definitely not the top shelf ones. Also bought some black ones from ebay, metal nuts that you tighten with the allen key. The centre of the nut rounded making some of them useless. I think its best to spend more front up and don't have to worry about it...
I tell you guys what IS the absolute best set of wheel nuts (sick aint it :D) I've ever seen or used, and that's Project MU's.
marlin is on the money with the project mu nuts. they are teh shit. the rays daytona ones i sold to ant are just as good too and are my favourite nuts. not nearly as hairy as marlin's are and screw heaps better too.
you may find the rays ones a bit cheaper than the pmu ones. I certainly don't think I sold ant his for anything like $400....
for those on a budget I use the plain, open ended but high quality (brand name) steel nuts. they are very strong and quite cheap around $30 per set of 4. will last forever if treated right. the high quality alloy nuts are better than the cheap ones. some even use an heli-coil like insert for the thread but none are as good as the top quality steel ones like the pmu or the rays daytona.
these are the budget option:
Work also make nuts that look identical to the rays ones pictured above and again reasonable in price.
these are the work ones. steel, open ended, another good budget option at around $100 a full set of 20...
these look good thanks for posting. can i buy them anywhere around sydney?
not sure. I've only ever bought them direct from work japan. with the rate how it is currently they are about $125 + post from japan. still not bad. they are nice nuts.
Finally discovered these (for those that want alloy):
They are about $100/set of 20, apparently locally manufactured using 7075 alloy.
ZERO issues with these, they have been faultless.
FWIW I tried those cheapie D1 nuts you see everywhere and they were no good after ONE wheel change, they stretched even at 108Nm. Junk.
 Share
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
    • For that influx of Spammers we had I made no pic posting and no PM's for first ten posts. This is group based and I've manually updated @Beanie to the Members group which will open up the images and PM's.
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
