I tell you guys what IS the absolute best set of wheel nuts (sick aint it :happy:) I've ever seen or used, and that's Project MU's.
If money is no object (and this is beer money for you guys), I can't recommend anything more than these. They're steel, but of a hollow design so they are still light, and they have a captive washer on them so they don't bind.
We use these on Mark's R34 time attack car, and although the wheels have been on/off literally hundreds of times, they're good as new. Got them from Racer Industries on the Gold Coast.
From memory they're around $300 per set. I'll get these next, as they've proven themseves to me as good economy. (Drip a little oil between the washer and the nut itself prior to first use, just as you would tightening head studs, they torque up beautifully)
This is the type we use;
http://www.project-mu.com.au/en/products/o..._nut_racing.php
I have some of these & would recommend them above any alloy nuts.
It is pretty simple - you don't want them failing. You don't want to have to worry about them failing. YOu don;t want to have to continually replace them.
On that basis they are actually pretty cheap. Light too for that matter.
  • Replies 50
that's me. i just cant bring myself to pay $400 for wheel nuts. i understand the economy argument, but yes i'm a tyt arse!
If you check the obvious import sites you should be able to get them for less than $250.
Also Nismo make steel wheel nuts in various lengths. they don;t appear to have the little collar on them like the project mu ones, however.
can't seem to find any project mu stuff less than the $390 price, any suggestions?
Mine never failed but damaged the thread both on the nut and the stud, it got so bad that I had to replace my studs
same here. studs damaged due to the soft alloy thread coming apart and mashing the stud thread. pita. got to watch them closely and clean as you go all the time. a damaged stud can ruin your whole championship (i carry a bunch of spares now..!)
thanks for that but nothey are not the correct ones.
these are the ones
Yeah sorry I realised after i posted them, I thought I had seen them on there before for around the same price.
no worries. i think i found some decent ones (aussie made i think) through meridian motorsport, $150/set. apparently quite good i will report on them soon.
bit late....but anyway, I gave up on ally wheel nuts after stripping one. Don't need that sort of issue.
The ones I have run for years are steel from my mates at autobarn. take a nice thin 17mm socket and fit in most wheels. they have a flange so they don't slide into the deep sockets. look like this....thanks ascii art.
. __
\___/
I don't have an issue with using a rattle gun to spin the nut if you have long studs, but always stop early and finish them by hand with a torque wrench (unless the rattle gun has actually been calibrated to the right torque, 110nm for standard studs). I have seen studs stretch and break from not torquing right, it is just crazy not to take the time to do this stuff right on a track car. I use a makita electric impact wrench then finish off with a warren and brown torque wrench, does not take too long.
  • 3 weeks later...
I was just told something very interesting relating to annodised alloy parts. I was explaining the problem (stripping a lot of these wheel nuts) and his first question was "what colour are they"........ They have all been red, and he went on to say that annodising them RED has a weakening affect on them. Something to do with the process of annodising them RED whereas other colours didnt have the same problem! (to the same degree) he had some hardness numbers to back up what he was saying. So that's interesting, anyone ever heard this?
My red ones are also stuffed!!! I don't remember what brand they were but I bought them for $120 a set so definitely not the top shelf ones. Also bought some black ones from ebay, metal nuts that you tighten with the allen key. The centre of the nut rounded making some of them useless. I think its best to spend more front up and don't have to worry about it...
I tell you guys what IS the absolute best set of wheel nuts (sick aint it :D) I've ever seen or used, and that's Project MU's.
marlin is on the money with the project mu nuts. they are teh shit. the rays daytona ones i sold to ant are just as good too and are my favourite nuts. not nearly as hairy as marlin's are and screw heaps better too.
you may find the rays ones a bit cheaper than the pmu ones. I certainly don't think I sold ant his for anything like $400....
for those on a budget I use the plain, open ended but high quality (brand name) steel nuts. they are very strong and quite cheap around $30 per set of 4. will last forever if treated right. the high quality alloy nuts are better than the cheap ones. some even use an heli-coil like insert for the thread but none are as good as the top quality steel ones like the pmu or the rays daytona.
these are the budget option:
Work also make nuts that look identical to the rays ones pictured above and again reasonable in price.
Finally discovered these (for those that want alloy):
They are about $100/set of 20, apparently locally manufactured using 7075 alloy.
ZERO issues with these, they have been faultless.
FWIW I tried those cheapie D1 nuts you see everywhere and they were no good after ONE wheel change, they stretched even at 108Nm. Junk.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
