I got an R32 GTR, but as soon as i start driving, the front torque gauge goes up to 10 and sits in between 10-50 most of the time. It only drops to 0 when stationary.
I've been driving it in RWD since i got it back on the road because I'm worried i might be stressing the drivetrain somewhere.
Any ideas what could be up with it?
https://www.sau.com.au/forums/topic/317627-4wd-problem/
yeap Duncan is right, i had the same prob, when i brought brand new tyres for the rear on my car, and left the shitty old ones on the front. Trips the Attessa out big time. Just rotate them mate, you mite think 10mm wont matter but for attessa will hate you.
https://www.sau.com.au/forums/topic/317627-4wd-problem/#findComment-5201667
