Hay guys, as the title says i'm after some bits for my newly aquired stagea.
**It's a series 2 RWD**
Im lookin for: passenger side weather sheild (it's missing?? I'l buy both if I must)
:some sort of lowered suspension maybe coilovers but im on a tight budget??
:exhaust??
:Front mount and piping kit??
:and maybe a touch screen double din stezza lol
I'm pretty broke atm so the cheaper the better lol.
https://www.sau.com.au/forums/topic/317641-wtb-stagea-stuff-in-sa/
hey buddy..
if your on a tight budget your best option is to get an rb20/rb25 fmic... you can pick them up for around the 3/4/500 mark, qaulity being the decider there.
see justjap.com?? for parts
they have new fmic, you want a bell mouth rb25 dump (not a split) highflow cat preferably... gutted will do for now if u cant afford it.
then just get your local zorst shop to mod you a r32 33 34 exhaust. many threads on here on how do do it.. mainly extending around the diff area.
you should be able to do a turbo back for under 700... i did mine for around the 550 mark
u dont need one of these 1400 ebay specials lol
stereo, just get a decent headunit the 1st time, then slowly build on it.
and for suspension... take the dice in your hand and play the game called '2nd hand suspension' remember... a can of degreaser makes the shittyest most raped coil overs look epic for photos and pick up!
welcome aboard!
edit: truth be known alot of ppl take off there weather sheilds...
Edited by chef_stagea
i got just the passenger one mate... my drivers side one broke a while back and haven't been able to find another one to replace it... or should i say i havent been able to find one under $100... pfft some people are so stupid...
Ait i'l take mine off and sell it to ya for $50??
Also lookin for some nismo smoked side indicators- s/h if possible?
for your exhaust go to nueckel auto care i got mine done for $400 and it sounds tough, cat back to resignators and a tip it give is a real nice tone all the way through and dosn't drone
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
