r32 gtr also regd till nov and i think i still got the rwc it was not long ago i got it changed under my name
http://www.calaisturbo.com.au/showthread.php?t=192588
also just got starter motor new clutch and lighter fly wheel, and got front rear struts and drilled rotors , and Monday going into the shop getting a computer check because revs are playing up and see if anythings wrong with it if so will be replaced or upgraded and will be getting a nice power full dyno tune and tires are getting replaced.
not sure if id want to do the deal but if your considering it then ill have a think because iv got few other offers so let me know thanks
Item: MY99 Impreza WRX
Item Condition: Immaculate condition
Reason for Selling: Want rear wheels drive
Price and Payment Conditions: $15,990.00
Extra Info:
- Rego till 04/11/2010
- 95,000 kms
________________________
I have a 1996 R33 GTST - Standard mods - FMIC, Turbo back exhaust, 72,000kms if your interested..
Thanks
Edited by White Ghost
Extra Info:
- 95,000 kms
Thanks
Hi, where are you located? any more info or photos of the car ?
Cheers
  • 1 month later...
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
