basically if i was to buy a turbo that will actually keep up with the rb25s hunger for air would 14 psi be too much? i would of course buy a haltech, malpassi etc... i just dont want to buy stuff if at the end my engine just falls apart.
https://www.sau.com.au/forums/topic/317716-series-2-1-bar-good-or-bad/
1 bar will be fine, stock engine will handle it. Just get some kind of ecu management and you'll be fine. I'm runnng just over a bar on mine at the moment without a problem, i also have plans to go higher :( Don't worry about an adjustable fpr, waste of money IMO. What turbo are you looking at getting?
Josh,
Do you think adjustable FPR is a waste of time? Im trying to weigh up if I should chuck a bigger turbo on my stag..... Prob would just get a high flow for ease of instalment and dont have to worry about defect... Ive got all the supportive mods (FMIC, Turbo back, SITC, SAFC, EBC Splitfires ect ect...)
What else would I need to run the bigger turbo at say 14ish psi? Fuel pump? Injectors?
Josh,
Yes get an upgrade fuel pump. Only reason to get an adjustable fpr is to push more fuel through your injectors than normal. For not much more money you can get a set of 480cc (or 550) injectors - a better idea in my view. Apart from a better turbo a quality professional tune is the key to max power.
Chris, as kiwi said, definitely get a new fuel pump, purely for the fact that the one you have now could be up to ~15 years old. fuel pump failure will cause lean mixtures and could potentially kill your engine.
adjustable FPR's can be used to allow you to get that little bit extra out of the stock injectors. the way i see it, why waste your time stuffing around with one running higher fuel pressures in a dodge attempt to save a little extra coin, just to find out that you are going to have to upgrade the injectors at a latter date anyway. adjustable FPR's have there place with aftermarket fuel rail setups that don't accommodate one, and then just use it to set the recommended base fuel pressure.
the only mods i'd add to your list would be, a decent fuel pump, and a better kind of engine management that the SAFC/SITC combo (all depending on the hiflows specs, you may get away with it). in the back of my mind would be injectors and AFM, but i'd wait to see how close to maxing them out i was first.
Ok so shopping list, feel free to make corrections and fill holes -
Management - nistune
turbo - ???
injectors - ???
Fuel pump - bosch 040
thanks for any info
what power level are you aiming for steven?
a couple of options could be, the GT3076 seems to be a favourite among RB25 owners. not too laggy and good top end result. but will require a different dump pipe, and oil/water lines, intake pipe. if your not after big power the smaller GTRS is a good responsive turbo and i believe they come in a bolt on kit that bolts up to the stock dump pipe pattern.
after you work out what power level your aiming for you can then size your injectors, if you need them. if you do 500-600cc is a good size to look at. you should go over to the forced induction section of the forum and start going through the RB25 dyno results thread and look at other peoples setups and the results they got.
I don't have a power figure I'm chasing. Just want a reliable 1bar. If I can get it to out run an aurion I will be happy. But it's more of a me being stuck in my old ways. My celica I set up to run 1 bar and it was just a nice number. ATM I just over the boost cut on cold nights. If possible I wanted to keep my stock outlet location on the turbo and still use my jjr dump.
just get a nistune board installed and tuned for 11-12psi on the stock turbo and you wont be far off that. stock injectors and afm will be fine. see how that feels and if you still want more then do the turbo.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
