All serious offers will be considered...$400 ono
Getting a full turboback system so this is up for grabs
...X-Force 3" stainless steel exhaust with mid muffler-cannon has 3" inlet/4.5" outlet
Will fit straight up to Nissan s14/200sx or r33 Skyline
Should fit s13/s15 [might need slight modification-not sure] will also fit r34 Skyline's & Stagea's
...It's actually a s14/200sx exhaust but i had a new 25cm mild steel extension pipe[not the decat in pics]
made so that it fits my r33 gtst Skyline-its doesn't knock on chasis at all & fits well
In pics cannon is sticking out too far but that was fixed after i swapped the decat for shorter section of pipe
...Pics of it on the car were a test fit
It's on my r33 now & fits well-send your email address for current pics
Also will fit most other cars if modifed
...GOOD POINTS...gives more power-no leaks/cracks-welds are allgood-mid muffler takes out the drone/not annoying on long trips-it hasn't been used for long/stainless has hardly discoloured yet-easy to fit yourself-light weight-not too loud on idel
...BAD POINTS...has scrapes/scratches on mid muffler & cannon-slight dent in muffler tip but hardly noticeable
Can send with courier at buyers expense-contact me for an accurate qoute
Pickups from Maroochydore-Sunshine Coast-QLD-4558
Will deliver within 150 K's from Sunshine Coast for extra fuel money
PM to contact
post-59075-1271879706_thumb.jpg post-59075-1271879884_thumb.jpg post-59075-1271879932_thumb.jpg
post-59075-1271879980_thumb.jpg post-59075-1271880052_thumb.jpg post-59075-1271880072_thumb.jpg
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
