Flushing Coolant From Block
Mid_Nite_R33
 Share
  • Replies 98
found where they are, to clarify, one is to the left of ur stock bov (if ur standing facing ur car) and the other one is just under the neo cover like the picture above..
to kong,
think of it as Spark Plugs the platinums arent necessarily better than the copper its just that the electrodes could last longer.. the cheaper coolants, after 30k would have chunks and rusts, the long life ones would have too, but fairly less..
so if u hate flushing ur radiator every 30k then might as well get the long life one...
to kong,
Would I be wise to have something with a rust inhibiter in the coolant? I'm not sure if mine has any. I don't mind changing out the coolant every 30k, and in fact I don't think it's too bad an idea. Going on how bad various parts were coroding until I discovered them, changing the coolant more frequently I think is a smart move. All I'm concerned about is, will I get better protection with more expensive coolants, or are you only paying for a long lifespan.
you do get slightly better protection, and it will more than likely have corrosion inhibitors in it. i'd check specs of the coolant you put in and just see if it does have the rust inhibitor in it. if it does then i'd just leave it in there for now.
also comes down to how much you drive the car. generally they will have a life span on coolants that isn't just how many kms, but also how many years. i think most coolants are supposed to be changed every 2 years or so if you don't have to change them earlier due to kms.
Soooooo...
I've been checking this thread for nearly 2 months now. Still want to know where the drain plug is.
Some say mission impossible. Any pics?
Mad082, you've said repeatedly to "use the drain plug, that's why it's there!". Where?!?! Pictures would be lovely but I'll settle for a vague description.
It's been alluded to several times but has as yet remains unanswered. Please help, I'm getting my new radiator soon.
Oh i see, so I gotta pull that thermostat out before flushing the bkock to sort of unplug the block in a way?
Also how can I tell the condition of the thermostat?, might as well replace it while im at it if need be...
much appreciated,
tom
good luck dude, best is just take it to some mate that can do it
  • 1 month later...
Here's a question...
does it matter than I put in some $5 cheap coolant that needs replacing after 30,000kms? I know it's not as good as the Nulon long life stuff, but I have no problem in draining it near the 30,000kms and refilling.
After my flushing the coolant has remained free from any scunge or rust coloured stuff. So it's been a success for sure. Just wondered really what's the difference between the various grades of coolant other than how many kms they last.
Coolants that meet Australian Standard 2108-2004 fall into two different categories, Type A and Type B. You will find the type of coolant printed on the bottle. The main difference between the two is: Type A engine coolant contains antifreeze/antiboil coolant with corrosion inhibitor, while Type B engine coolant contains corrosion inhibitor only. In other words, Type B contains no glycol (antifreeze). This info is straight from the standard which I have in front of me.
Type B is the stuff you will often see labeled "for pre-1984 vehicles only". Type A will have a higher boiling point and lower freezing point due to the glycol. Note that there is no requirement for the premix Type A stuff to have a certain glycol level. This is for the manufacturer to determine.
There are other requirements to meet the standard such as pH, glassware corrosion levels, coolant hose immersion test, etc. One of the ones you can test yourself is foaming. If you shake the bottle of coolant, any foam that forms should disappear within 5 seconds.
I don't want to make recommendations because everyone's situation is different, but any Type A coolant with a glycol level of 33% is 'probably' going to be fine for normal street use in typical Australian conditions. I wouldn't run the Type B stuff because of the lack of boiling protection, especially if you like to give the car a good thrashing.
Nulon are fairly transparent about their product, which I like. You can see a comparison of their coolant's test results and the relevant standard here (click on specifications in the link): http://www.nulon.com.au/products/Long_Life...trated_Coolant/
Some people swear by the genuine Nissan stuff, others swear by Toyota coolant. Or perhaps you have an aluminium radiator and run the red stuff. Do your own research and decide what's best for your Skyline.
  • 5 weeks later...
in relation to the block drain bolt .. from what I remember reading it's on the RHS of the block somewhere near the exhaust manifold.. But anyway, with all the heat/cool cycles over 10+ years I'm sure this mofo bolt has become very rusted on part of the block so I'm not sure unscrewing it for the first time since it was put there in the factory would be the smartest thing to do. ie. what if it breaks? Which is possible considering its probably never been touched before and is rusted onto the block.
I'm starting to think that maybe there is some sort of suction device with a long thin hose that you can feed into the block to "vaccum" all the old coolant out ..
  • 2 months later...
i just did a quick flush on my r34
droped old coolant,flushed radiator then filled and ran car and flushed a few times more
then filled with fresh coolant
what i DID'NT do was bleed the system afterwards(misses rang had to run :( )
should i be worried ?
should i do this?
seen the nut near plenum is this the one?(do not open when hot)
should i not worry about it?
car seems fine runs nice no overheating never goes past half on the temp gauge
cheers
  • 11 months later...
I just read this thread.
I have rusty coolant in my radiator (GodSpeed) and it literally smells like fish. This situation has promoted me to purchase a new SARD rad, nismo stat, and samco hoses. The hoses are a 'might-as-well' purchase... My track my R34, BTW.
I don't know if there's rust in the block but I want to completely flush out the engine and my Garrett turbo since it's coolant-cooled. How do I completely flush/remove the rust out of the system and not containment the new rad?
When I changed my turbo, I lost my coolant. It took about 7l to full up so I'm guessing most of my block was drained. All I disconnected was the water line from the turbo.
I think the turbo should be easy to clean since it's a relatively small coolant passage. My main concern is the new radiator. I want to avoid getting any sort of rusty coolant in it.
Yeah I know, but what I am saying is just by opening the turbo water line, I had most of the water coming out. You can maybe even get a hose into the water port on the turbo and flush the system that way. As long as you can get into the water system and fit a hose there, you can flush it.
Thanks, mate. I'm going to try a little magic flushing out the block with the old rad removed and the new one uninstalled. I don't have any sort of machines so I'll have to accomplish this with a friend a few cans of beer.
 Share
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
