Just wondering if you guys had any ideas regarding a weird problem I have with my skyline.
When the car is warm and I stop to idle...the revs rise to about 2000 rpm and then hold there and then drops down to 1100 rpm. When it is cold it smoothly idles at 7-800 rpm? Just when it is warm it is high.
I took it to a mechanic and he said it could be any number of things but he thought it could be the computer thinking it is an auto (I did a manual conversion), but somehow I am not sure about that.
Anyone else had a problem like this switching from auto to manual?
Help!
https://www.sau.com.au/forums/topic/317743-rising-revs/
I used to get that same problem with my Ford Laser, did some tampering with the idle and when i lowered it it somehow fixed it, one of those things that doesn't make logical sense but works...
Ofcourse, that was a car that was manual out of the factory, so it could have been a completely different issue to what your experiencing, it sounds like your on the right track by assuming its a tuning issue due to the conversion.
https://www.sau.com.au/forums/topic/317743-rising-revs/#findComment-5197674
I tried lowering the idle a ways back but it was already as far back as it would go from memory. I'll try again.
I don't think it is the tuning because the guy who installed the box made it so that the car thought it was in neutral all the time. If he did it in drive it would do it I would imagine. I'll just have to do some more tests and fiddling around.
cheers,
Dan
https://www.sau.com.au/forums/topic/317743-rising-revs/#findComment-5200048
I found this - http://www.skylinesaustralia.com/forums/Di...;hl=rising+revs. I might try this out, because it sounds more like the problem. I have A/C off most of the time and the A/C doesn't work neway.
https://www.sau.com.au/forums/topic/317743-rising-revs/#findComment-5203170
Hey mate, i know the problem all too well next time you have the high rev, take the wire going into your Throttle postion switch out. Once you do this it confirms the s if the rev's drop, if so then you need a new throttle postion sensor. I forget how much they are but i can order them at nissan.
https://www.sau.com.au/forums/topic/317743-rising-revs/#findComment-5208634
Many thanks,
I'll check it out. My cousin mention the tps as well. I'll give it a go. Where is it in the engine? (sorry for my ignorance), I will have a look around to see if I can find it.
https://www.sau.com.au/forums/topic/317743-rising-revs/#findComment-5209950
if you stand at the front of your car you will see the throttle body has a small box attached to it (has a wire and a plug if its a series 1 or if its a series 1.5 it will have the S2 TPS but 1 of the plugs has no wires going into it and the S2 has 2 plugs both wired up). Shouldnt be able too miss it now
https://www.sau.com.au/forums/topic/317743-rising-revs/#findComment-5210877
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
