Thought I'd pop in and say Hi to all :)
I'm a brisbanite who'll shortly be shipping myself south (next couple of months - work pending) :(
I'm thinking of moving into the footscray area, otherwise it'll be Box Hill/Blackburn.
Few q's :)
How's the cruise / motorsport / drift scene in Melb??? I want to get stuck into track days and hill climbs more when I get there. Which tracks (and where) have open sprint days and the like?
What is the police-import relationship? do they beat us with sticks? or let us play somewhat?
Are pod's legal in VIC? Is VIC Roads the best place to go thru to ensure my car's legal so I don't have to worry about defects?
Cheers,
Michael
https://www.sau.com.au/forums/topic/31775-possible-move-south-d/
Yowch :( cops are really that bad... How about defects? are they quick to throw that pad on your bonnet and write you up?
Yah, I used to live in Blackburn and I've got a few friends there too. I know the area fairly well (but I'll be buggered if I can remember the names of most of the streets :) )...
Melbourne is great... apart from the weather. I think you will find that as long as you join the right car clubs, you will get to spend plenty of time on the tracks.. only problem is they are a fair drive out of town.
Tightarseness of cops is pretty similar to QLD. Dont rice your car up too much and u wont have too many problems with defects. When you bring your car down, you dont need to get a RWC. Just need to chuck it on a weighbridge, hand in your old qld plates and pickup vic plates... so no worries there.
Dave
Tracks - Sandown (2 clubs I'm associated with have driver training days each year). Lots of events at Phillip Island (1.5 hrs from Blackburn (south)) and Winton (2.5 hrs from Blackburn (north)). Then there's Morwell Hillclimb (1.5 hrs from Blackburn (east)).
If you want access to these tracks, I'd recommend Nissan Datsun Sports Owners Club (I'm the secretary, so I'm a bit biased).
Cops are OK if you behave yourself (been followed by cops, they never bothered me, despite the GT-R wing on the back, because I didn't do anything stupid).
As Jet-33 said.... Move to blackburn.....
I wouldnt live in footscray if i armed every dodgey ass mofo i knew with an ak47 each to protect me :bahaha:
they are all dodgy, move to Toorak :(
nah seriously, most melb suburbs arent too bad... most 'pov' suburbs still have really nice houses etc... usually nicer than inner city expensive suburbs.
"wouldnt live in footscray if i armed every dodgey ass mofo i knew with an ak47 each to protect me " lol - advice taken heh...
Tx Blind Elk :rofl: I'll be at as many track days as possible - all going well ;)
"If you keep your QLD Plates can they defect you?" - rego's $200 cheaper in VIC...I think I'll just be changing my rego over ;)
Should I get an alarm...how's auto theft in Melb
Not sure an alarm is such a useful accessory - had some little junkie sit inside the car and remove the radio; all the time, the alarm siren must have been having a fit, of course, no-one paid the slightest attention, but then it was at a rail station.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
