  • Replies 41
If your AFL players arent driving around on the piss drugging groupies then your NRL team are sweeping countless dollars under the table in dodgy dealings! :down:
You wouldnt catch any Sydney folk behaving like that...well apart from Balmain and Canterbury teams/fans :D
Not that I give a fuck about AFL / NRL, but the headlines we get in the news about some jock with his mishap is just stupid.
They are overly hyped and it is none of our business.
Are these ppl suppose to be role models for younger players / AUS people..?
If so then it's not proud to be AUS.
yeah....at least our football players dont shove there fingers in other guys arse's......so think yourself lucky we are not like the queenslanders that play in sydney....huh huh huh???
Edited by ylwgtr2
Actually, lingerie football is better sport to watch...
I didn't know you feel that way about men..... in lingerie.... playing football....
LOL jk :D I actually saw that a few times on Foxtel xD Would be good if I actually know how NFL works, so it doesn't make me look like I'm cluelessly watching girls running around in lingerie with a helmet on lol.
Arhh well. If thats what it takes to get ahead :down:
On a side note. Who cares about AFL and rugby etc. 90% of the people that play them are hardly the brightest or most useful beings in society. Odviously not all but yeah. Not a fan. All a bit pointless to me
** gets ready for flaming ** - (but doesn't care what the reactions are :D )
Add money to it, they're just a bunch of cry babies who doesn't like too much attention - their fault for being famous.
My 2 cents.
p.s. I wouldn't want to see men playing lingerie football!
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
