Hey guys,
Just began putting on my new turbo which is water/oil cooled.
My current turbo is only oil cooled and thus the water lines were blocked.
I took off the pipe that was blocked off to this t piece that sits at top driver's side area of the engine and this is what I found in the t piece....
post-36975-1271922749_thumb.jpg post-36975-1271922798_thumb.jpg post-36975-1271922820_thumb.jpg post-36975-1271922874_thumb.jpg
the one thing to note is that the tube that is completely blocked with crap is the pipe that was blocked off.... don't know if that means anything..
questions:
is this normal assuming the system has not been changed since car was made?
should I be worried?
finally, over the past few months I have noticed that the car is slightly hotter in normal running temp then normal... ie instead of 78-80 it would be 80-81.... but performance was/is still fine..
Thanks,
Adam
https://www.sau.com.au/forums/topic/317777-is-this-crap-normal/
It's pretty normal to have a bit of shit in the cooling system.
It will tend to accumulate where you have a blocked off line as the water isn't flowing.
Just give it a flush next time you change the coolant.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
