hey guys
leaving work tonight, got in the car started fine pulled out drove 3-4 kms up the road and stopped at a red light.
took off quickly to get infront of the car next to me as i was merging (definately far from drag racing) reached about 70kph and the car started to shudder and stall. it came to a stop and died.
- the car starts but only lasts a few seconds, however it doesnt quite idle and just dies and you can't rev it to catch it. just dies.
- it has plenty of fuel in it
so it has spark, fuel, power, starter.... everything. i dont know what it could be.
any thoughts or anyone experienced this?
im going to tow it to Nissan tomoz as there is one close to my work. - hopefully nothing major.
https://www.sau.com.au/forums/topic/317783-nm35-died-mid-flight/
  • Replies 54
Posted Images
hey guys
might be the AFM.....see if there is a difference when it's unplugged and you start it.
Funny, ive never heard of a decent (read VQ) afm getting dry joints, still it could be. Was it out in the rain? The hotwire could have gotten wet?
Are you running the powerduct? That could let water in from the front.
lol....smart arse.....Danny's died mid flight a while back!....mind you he had just put a Stillen set up on.
i am running powerduct. so whats the theory? water has gotten in and messed with the AFM?
i doubt fuel pump. i can hear it when i turn the key to accessories sounds as it does always.
Check the intercooler end tanks haven't burst too.
Either way there are parts around. I have Craigs intercooler down here if you need it. lol
I also have the stock pump in a box somewhere.
someone's a parts whore!!!! :D
its at work locked up for the night.
so ill try to start it again in the morning - hoping its water in the AFM.
if not ill have to tow it to Nissan.
ill let you know how i go scotty and if i need any parts.
cheers
Just a whore in general I think.
Not much need for them now eh Craig? :D
I don't think it will be the crank angle sensor. When that fails the motor just turns off.... there is no in between, it runs then it stops.
The loss of power and shudder sounds more like a leak in the intercooler piping. I remember seeing Danny's car going like that when a pipe popped off. He could start it but it would stall straight away.
ok well it started this morning.
its idleing but the engine light is on. and it wont rev very well.
the guy from nissan told me over the phone it sounds like its in "Limp Mode"
but Nissan dont want a bar of it. and claim they cant help.
get the error code......then reset the ECU.....see wether it faults again
http://www.skylinesaustralia.com/forums/Ob...m35+error+codes
AFM is stuffed would be my bet.
Happened to my mates M35. Run as rich as hell, idled poorly (obviously) and couldn't push it pas about 2200rpm.
I may have a second hand AFM lying around.... or you could just get an Xtrail's AFM from Nissan and plug it straight in (my mate has a 350z AFM which works fine)
i drove it home and swapped it with my motorbike for the day.
it has NO BOOST. so im guessing it is turbo/cooler related.
watching the gauge it moves up but when it gets near 0 it starts to shudder.
so could it be a rooted cooler?
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid AASA General speed licence Or (Day license is $35.00 via the AASA Website) MA licenses no longer accepted A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2.  3.  4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
