AFM is stuffed would be my bet.
Happened to my mates M35. Run as rich as hell, idled poorly (obviously) and couldn't push it pas about 2200rpm.
I may have a second hand AFM lying around.... or you could just get an Xtrail's AFM from Nissan and plug it straight in (my mate has a 350z AFM which works fine)
I will borrow your spare if thats ok and swap it to see if it makes a difference.
i might pick it up over the weekend if thats cool??
let me know dude, cheers
  • Replies 54
Posted Images
intercooler pipe has likely blown off, lol at the internet mechanics
Lol at internet comment repeaters. Good thing he wasn't waiting for your sage advice. A day late and a dollar short. Well done friend.
what,you think i get my knowledge from these forums and the internet? has the guy resolved the problem?have you got a better call cockmaster? dont call me friend either
Settle down please. Insulting other peoples suggestions, while repeating someone elses is hardly a pioneering strategy, nor will it win you many friends. I actually weighed in on this issue several days ago if you cared to look before insulting someone you've never met. But hey, you're the only person on this forum with a valid opinion.
My rule of thumb is; if you wouldn't say it to someones face, don't say it on a forum. I can assure you, you wouldn't be having that conversation with me. Your sig is right; you're as subtle as a brick to the face, and about as welcome.
aerofocker and Daleo you can both settle down, if you want internet arguments Forced Induction Performance is over that way somewhere ---->. Stagea section is for grown ups.
Anyway, I tried twice and wasn't going to post again in here...but I'll try again for luck. aerofocker, although not polite is almost certainly on the money.
Have you actually checked for an intercooler pipe problem?
It is 10x more likely than an afm/fuel pump/fpr/earth or whatever other suggestions have been made. The pipe will most likely be on but not tight (eg loose clamp, or maybe a large split). It is only opening badly under boost. It idles better or worse some times depending on how well the pipe is sealing without any clamping force on it.
Yes it is harder to check than changing an AFM but I generally try and work on the most likely cause instead of the 1% long shot.
Thanks for the help guys, I have had a good check of the piping and cooler, I believe the car is in limp mode so it's not letting me get to boost rather than it not being there, I'm swapping the afm today and will let you know how I go. Cheers
well i had a similar episode in my 'line...
i was boosting out of a roundabout one night and suddenly lost all power, she coughed, and then died! I had heaps of fuel, was cranking fine, just wouldn't start. managed to get it to run rough and limp it home, found out next morning my shitty pod filter end cap had sucked right the f**k off the filter, and up against the AFM wire, so that it couldn't register any air flow, and three fifths of f**k all air could actually get past anyway. i simply removed the offending filter cap, replaced with a k&n and bingo!
i dont know if you have a pod or not, but hey thats my two cents, and what happened to me. i guess the simptoms of what happened to me and blown piping are the same because the problem is the AFM not getting a signal.
cheers, Rowdy.
im here to solve the dilemma guys
i swapped AFM's this morning with Cam and worked a treat.
resetted the ECU and all good.
thanks for all the help. would have been in the dark without Scotty and Cam.
Nice to have some "internet mechanics" that know what is going on, aye? :blink:
smart arse.....yes you are...LOL
I will defend my call of intercooler leak as at that point we had not been told about the engine light coming on.
Once that was in the mix, had to be an electronic fault....
:D
No need to defend yourself andy, it was a good call. :blink:
I have asked Garett to bring the sensor around to have a look. It's probably a dry joint on the cct board and I want to see if it is repairable so we dont need to replace them when they fail.
it was just a shot back at Cam....LOL
ill come past next weekend Scott if thats cool with you.?
Really!!!
AFM wasn't it! lol....work at a dealer servicing car's aye!...only asking because your diagnosis was about as accurate as there's would have been!
P.S. Most of us know our car's fairly well....you got some kind of in site into VQ25DET's that we don't know and you can share. Before you slag off the so called internet mechanic's maybe you should at least work at getting you diagnosis correct first!....and remember that some of us have quite a high level of first hand knowledge!....remember this isn't REXNET!
Edited by Jetwreck
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
