AFM is stuffed would be my bet.
Happened to my mates M35. Run as rich as hell, idled poorly (obviously) and couldn't push it pas about 2200rpm.
I may have a second hand AFM lying around.... or you could just get an Xtrail's AFM from Nissan and plug it straight in (my mate has a 350z AFM which works fine)
I will borrow your spare if thats ok and swap it to see if it makes a difference.
i might pick it up over the weekend if thats cool??
let me know dude, cheers
  • Replies 54
Posted Images
intercooler pipe has likely blown off, lol at the internet mechanics
Lol at internet comment repeaters. Good thing he wasn't waiting for your sage advice. A day late and a dollar short. Well done friend.
what,you think i get my knowledge from these forums and the internet? has the guy resolved the problem?have you got a better call cockmaster? dont call me friend either
Settle down please. Insulting other peoples suggestions, while repeating someone elses is hardly a pioneering strategy, nor will it win you many friends. I actually weighed in on this issue several days ago if you cared to look before insulting someone you've never met. But hey, you're the only person on this forum with a valid opinion.
My rule of thumb is; if you wouldn't say it to someones face, don't say it on a forum. I can assure you, you wouldn't be having that conversation with me. Your sig is right; you're as subtle as a brick to the face, and about as welcome.
aerofocker and Daleo you can both settle down, if you want internet arguments Forced Induction Performance is over that way somewhere ---->. Stagea section is for grown ups.
Anyway, I tried twice and wasn't going to post again in here...but I'll try again for luck. aerofocker, although not polite is almost certainly on the money.
Have you actually checked for an intercooler pipe problem?
It is 10x more likely than an afm/fuel pump/fpr/earth or whatever other suggestions have been made. The pipe will most likely be on but not tight (eg loose clamp, or maybe a large split). It is only opening badly under boost. It idles better or worse some times depending on how well the pipe is sealing without any clamping force on it.
Yes it is harder to check than changing an AFM but I generally try and work on the most likely cause instead of the 1% long shot.
Thanks for the help guys, I have had a good check of the piping and cooler, I believe the car is in limp mode so it's not letting me get to boost rather than it not being there, I'm swapping the afm today and will let you know how I go. Cheers
well i had a similar episode in my 'line...
i was boosting out of a roundabout one night and suddenly lost all power, she coughed, and then died! I had heaps of fuel, was cranking fine, just wouldn't start. managed to get it to run rough and limp it home, found out next morning my shitty pod filter end cap had sucked right the f**k off the filter, and up against the AFM wire, so that it couldn't register any air flow, and three fifths of f**k all air could actually get past anyway. i simply removed the offending filter cap, replaced with a k&n and bingo!
i dont know if you have a pod or not, but hey thats my two cents, and what happened to me. i guess the simptoms of what happened to me and blown piping are the same because the problem is the AFM not getting a signal.
cheers, Rowdy.
im here to solve the dilemma guys
i swapped AFM's this morning with Cam and worked a treat.
resetted the ECU and all good.
thanks for all the help. would have been in the dark without Scotty and Cam.
Nice to have some "internet mechanics" that know what is going on, aye? :blink:
smart arse.....yes you are...LOL
I will defend my call of intercooler leak as at that point we had not been told about the engine light coming on.
Once that was in the mix, had to be an electronic fault....
:D
No need to defend yourself andy, it was a good call. :blink:
I have asked Garett to bring the sensor around to have a look. It's probably a dry joint on the cct board and I want to see if it is repairable so we dont need to replace them when they fail.
it was just a shot back at Cam....LOL
ill come past next weekend Scott if thats cool with you.?
Really!!!
AFM wasn't it! lol....work at a dealer servicing car's aye!...only asking because your diagnosis was about as accurate as there's would have been!
P.S. Most of us know our car's fairly well....you got some kind of in site into VQ25DET's that we don't know and you can share. Before you slag off the so called internet mechanic's maybe you should at least work at getting you diagnosis correct first!....and remember that some of us have quite a high level of first hand knowledge!....remember this isn't REXNET!
Edited by Jetwreck
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid AASA General speed licence Or (Day license is $35.00 via the AASA Website) MA licenses no longer accepted A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2.  3.  4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
