Very cool, i was surprised by the flame on ignition, i'd always thougt it would look more well.. eveen... not so scattered.
must have been an american engine then lol
probably some sort of thick glass window infront of the lense or some sort of extreme heat risistant plastic????, i'm assuming the camera lense was drilled through the block wall and the rest of the camera was still away from the heat.
Cool vid...pretty clever whatever they lined the cylinder bore with to get a peek in there. Though given the piston doesn't go past the camera it's probably an ultra thick head gasket they drilled out and engine is running on real low compression.
If you thought that vid was cool, well this one isn't as good, but its still interesting....
http://www.dpccars.com/car-videos-10/04-23...Nissan-370Z.htm
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
