hi im looking at inter coolers on just jap and was wondering how much difference there would be between these two inter coolers when it comes to
cooling
turbo lag
ease of fitting
heat soak.
i intend on meshing the front bar to hide the intercooler from the cops interest so the shine of it doesnt matter (unless haveing mesh in front of it serverly affects the performance )
here they are
http://www.justjap.com/store/product.php?p...=339&page=1
thanks for your help
The Blitz one hands down. Larger core and overall will be better quality. All the things you listed are marginal given the two kits and nothing you would ever notice on a normal/mild setup. I'm assuming you have a stock turbo?
Also a heads up, intercooler is one word.
Edited by PM-R33
lol thanks man
ok so im better spending the extra money
also if i were to put mesh infront of the intercooler would it affect it ? iv seen cars with this so the cooler doesnt stand out ?
If you don't plan on going for over 280rwkw... IMO the cheaper one is better value and both should perform pretty much the same.
The Blitz should excel further once you push things more as generally the cores are better.
cooling
turbo lag
ease of fitting
heat soak.
here they are
Ok firstly I would always go with a well known brand name. I have personally never heard of cooling pro.
Just by looking (which is inconclusive in most cases) the blitz core appears to be of much higher construction quality and the end tanks appear to be pressed, not cast (pressed being lighter and stronger).
Also there is no photo of the inside of the cores, so you cant see how much metal/fins are inside each tube/bar. You must remember here that this can be a compromise between cooling, efficiency and flow but usually the big brands get it just right. It can also depend on what power figures your chasing.
For example, I currently have in my possesion a Hybrid GT2 core and a Greddy spec M core and the spec M core is far superior as far as fins per inch both inside and out are concerned. However the Hybrid core will do just fine for my power figure and set-up not to mention that nearly any aftermarket core will be superior to the factory side mount core. I am now using the hybrid core with great gains.
Also keep in mind that the stock R34 core is twice the size as R32, R33 and are said to be good for up to 200rwkw.
Another thing is that the cheaper brands usually still need to be modified to fit (i.e cut/trim piping) regardless of the fact that they claim it is a direct bolt on. Although having said that no direct kit will fit if, for example, the car has had an accident resulting in structure/frame work of the body being slightly or dramatically shifted.
Food for thought.
thanks for the great info mate yeah i heard the standard side mount is ment to be good but the other day i drove to the shops and back to get a pod filter and was suprized how hot the out let pipe of the inter cooler was,
but i think it comes down to my series 2 bumper for a start, that thin pushe air everywere but were its ment to go lol.
so first step ot to find a series one bar then get it painted to match , and while im fitting it i wanted a cooler to install at the same time ,
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
