I've driven a host of new Aussie performance cars. The turbo ute isn't as controllable as the SV8, although it's line-ball in acceleration and can carry enough kegs of bundy n coke to have you pissed into 2006.
I'd look at the lease deals you can get with SS Commodore Utes. They're very, very good.
  • 3 weeks later...
Guest MFX_R33
  Quote
Any when trying to drift i typically have a 15-30km/h lower corner entry speed, otherwise all i get is a bit of oversteer on corner exit. That means you are typically doing 60-80km/h on most of these turns...
That is not drift, that is a bit of power oversteer on exit of the corner.
In Drift you are usually going 15-30km/h FASTER than you would normally take the corner, and flick the steering early (feint-o) to get sideways before the corner and continue that all of the way through.
When travelling faster you are on the edge of traction from the start so even if you are slightly understeering on entry, all it takes is a tiny bit of the right foot to get the tail out.
Using this method you can drift in almost any car regaurdless of the power level.
Jeff.
Jeff.
Jeff, your MAD :D Im not brave enough to go into the like of turn 2 at eastern creek at 100km/hr, sure some corners i may feel confident going in too hot and washing off speed thru the corner when the car is punted sideways.
Guest MFX_R33
I haven't driven on EC, so I don't know turn 2, but that is what drift is. Just putting your foot down when you exit a corner is not drift.
You need the high entry speed to get the car side ways before the corner, just look at some of the D1 competitions and you will see what I mean.
Jeff.
Yeh i know what your saying , but your corner speed is still way lower then normal...even if the actual corner entry id higher...the lead up to the corner as you say is higher again
The only way i can drift is to still be braking on turn in so the car steps out, i cant scandanavian flick, nor do i like the idea of using the handbrake....practice makes perfect!
  BACKUP said:
yo what new non import cars are there that look good and drift alright as well
any car thats about upto mid 40s$$ brand new coz i can get good deals on them
so RWD or AWD any help at all thanks :D
ummmm.... non import car brand new....for ~$45k hmmmm a BMW?? prolly best to try drift one of them.... or the XR6T or and RX8?? but apart from that with that price range for a brand new car that is a NON import your really cutting it fine... :rofl:
Guest MFX_R33
The only BMW that would come close to that price range is a 318i (new they are stll well into the $50k range), and if you have driven one, you will know they don't have enough power to pull the skin off of a toasted marshmallow.
XR6T would be worth looking at.
Jeff.
my mate owns a stock as a rock r31 pintara. he can get that thing sideways. what the **** r u guys talking about?? if the driver has the know how and the balls to flick his machine into a corner, and the suspension can handle it, then u can do awesome drift in a 1977 carona, or a go-cart even. no shit. maybe u can't really fry the tyres has much as something with more grunt,but all this talk about what is better for drifting is kids drible. mfx r33 is right on the money.
like i say, drift is speed, not power.
Jeff.
SV8, ba xr6 turbo? both excellent cars for average performance and stylish power oversteer but way to fragile for real drift. 1. the sv8 has weakish diff, 2. handbrake does not like repeated abuse, 3. powersteer cooks itself crazy. XR6 ute has weak box, same diff dramas but slightly better hbrake setup. BOTH WEIGH way to much and therefore stress all their componentry to much for reliable drift. it is all well and good to say look at the touring cars but, these cars have fabricted or modified everything. From suspension parts and geometry to brakes and body bracing all of which is specialised considering the small market and well beyond the average punters wallet, especially after buying the car new.
Recent trips to japan had me watching late model chasers and verossa's and even some 350z's cutting serious drift with easy to get over the shelf parts.
Chasers are near new, compliance is avail and parts are aplenty (ex-japan, no stress) MAX 35k for car, 1.9k for sus, 2k for cooler kit, 1k for jap exhuast, 1.5k for 1.5 or 2way mech diff, 2hunge for decent brake pads and you have a slick practical (shopping and shite) drifter with around 240rwkw. ALL FOR WELL UNDER 50k.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
